Old 05-31-2014, 10:30 AM
sota sota is offline
HD300 Display Corruption via Yamaha Amp
I'm having a strange problem with my HD300 since buying a Yamaha RX-V675 surround amp. The HD300 is fed to a Samsung TV via the HDMI1 input on the amp and in dark scenes, you can see varying amounts of blue "noise" - it's like a lot of short, thin blue vertical lines scattered across the screen.
Feeding the HD300 directly into the TV removes the noise, and I have tried different inputs on the Yamaha to no effect.
The output resolution on the HD300 is set to 1920x1080p@50, but reducing it to a lower resolution removes the noise. However, I would prefer to be able to use it at full resolution.
Has anyone seen anything like this?
____________________________________________
Sage Server: Intel Core i5, 8GB RAM, Win10 x64
Video Sources: TBS 6985 Quad DVB-S; Mystique SaTiX-S2 Dual DVB-S2; HVR-2200 DVB-T
Client: 2 x HD300; 1 x Win 7 PC
Old 06-01-2014, 10:17 AM
Bucsfan2008 Bucsfan2008 is offline
Smile
In the US, it should be 1920x1080p@60. If it is showing@50, this may be the problem. Try force setting your HD300 at the 1920x1080p@60 and see what that does. Otherwise, you may just have an issue with the amp, because i'm not sure why the HD300 would show a native 50. Hope that helps.
Old 06-01-2014, 10:48 AM
Thanks, but I'm in Ireland so we are on 50Hz and I don't get an option for 60Hz. I'm trying to arrange the loan of another amp to see if that sorts the problem.
Old 06-06-2014, 04:01 AM
ccsmoke ccsmoke is offline
Might be HDMI cable, I think the HDMI cable that comes with the HD300 maybe on the thin side. A CL2 rated 24 AWG HDMI or better may cure the problem. Sounds like a bandwidth issue assuming the receiver is set to pal format in advanced settings.
Yamaha receiver remote codes and HD200 - HD300 tvmaster2 Hardware Support 0 11-13-2011 04:50 PM
HD300 Powers but no display on tv Bone SageTV Media Extender 8 04-04-2011 03:19 PM
HD300 1280 Window on 1920 Display Sagebrush SageTV HD Theater - Media Player 2 02-17-2011 09:00 PM
Tip: Calibrate Display Using HD300 peternm22 SageTV Media Extender 0 09-27-2010 12:08 AM
S/PDIF, PCM, AC3, DTS, Sage TV, Yamaha Receiver OldPCGUY SageTV Software 2 05-29-2008 06:49 PM
