Signal Breakup at adverts
Using the 6.4.8 beta, and some of the earlier 6.4.x betas I generally the system works fine however when the channel cuts to adverts, or back from adverts to the main program, the tunner seems to loose sync. If its a recorded show, and I stop and restart playback it will be fine until the next cut to advert or back from advert when the same will happen again.
Im using a Blackgold BGT3540 with one of the two DBS-T tuners. As far as I can see the comskip function is turned off, but Im guessing from the time this happens that there is some kind of related issue. Can anyone give me any clues please? |
Hi,
I'm using the older twin tuner (no dvb-s2). It works fine now and has for ages. I do remember having some issue a bit like this right at the start, but this resolved itself as soon as I used the Nvida codec. I don't know if this is the same issue as for you. btw, I am considering getting one of these myself. Have you tried this with Freesat for DVB-S2 HD yet? This would be the reason for me getting it so would be very keen to see how this works? Cheers, Mike
SageTV Server 7.0.23 - SageTV Client on 50" Plasma - HD100 Extender on 42" Plasma - HD300 on 92" Espon EH-TW3200 Projector ![]() |
Cable signal issues and HDHR | kevine | Hardware Support | 13 | 07-07-2008 06:29 PM |
Searching for Satellite Signal... | BFisher | General Discussion | 9 | 05-18-2008 11:38 AM |
What is S/PDIF? - FYI | gplasky | General Discussion | 0 | 03-07-2008 07:16 AM |
Signal mystery | pgitta | Hardware Support | 4 | 07-22-2006 04:09 PM |
Stutter/Jitter using A180/Vbox and OTA? Check signal "Strength" not "quality" | svemuri | Hardware Support | 0 | 12-13-2005 10:51 AM |
