SageTV HD Theater - Media Player Discussion related to using the SageTV HD Theater as a Media Player, i.e.: in use while not connected to a SageTV server. Questions, issues, problems, suggestions, etc. relating to using a SageTV HD Theater as a Media Player should be posted here. Use the SageTV Media Extender forum for issues related to using it while connected to a SageTV server. |
ENUWI-N trouble
I just got my HD200 today. I don't want to run cable through my apartment, so I got the Enwin ENUWI-N to connect wirelessly to my D-Link DIR-655. Unfortunately I'm having issues connecting. The HD200 came with a firmware from 2008, so I brought it into my office and wired it to my router so I could update the firmware. It's using the 20090903 0 or something. Whatever the latest version is.
Any time I try to connect wirelessly, I get the "wireless access point connection has timed out" error. The adapter detects available networks, so it appears to be functioning properly. The HD200 works fine with a wired connection, and I even got it working with my WHS system, so I can't deduce the issue to either device. My router is still a suspect, but it appears that the adapter can't even attempt to connect, as it simply times out. An Amazon reviewer of the adapter says it connected to their DIR-655 just fine. I'm at a loss now. I don't know what else to try. I just need to get it to stop timing out. Do I need to downgrade the firmware to this one? Last edited by GJSNeptune; 09-24-2009 at 07:44 PM. |
I connected the ENUWI-N to my main computer and disabled the LAN connection. The adapter works fine, so there's something wrong with the HD200. Should I try a firmware downgrade?
Hey GJ,
Try a few things before returning the HD200. First, I'm wondering if your network security is not connecting. Do you have upper and lower case letters in your security password (I don't know if you are using WEP or WPA). This happened to me, because entering the WPA key from the remote, you can only enter upper case letters. My WPA key was mostly lower case. Your router log file should tell you if you are getting access issues. Second thing to try is make the IP address static. You will have to reserve the IP address on the router and configure the setup in the HD200 (it is actually pretty easy). I've got two HD200s running with the wireless connection. Where it is not the level I would hope, it is still a lot better than plan b (which was to configure a wireless bridge to a access point on each HD200 unit). Good luck! Let me know how it goes. Joe. |
Also take a look at your encryption type. I am not certain the firmware supports WPA2 AES (unfortunately)
B
Running SageTV on unRAID via Docker Tuning handled by HDHR3-6CC-3X2 using OpenDCT |
The key contains lowercase letters, which I entered. My router security is set to auto (WPA or WPA2), which should allow any device that supports either or both to connect. I'll mess with it tonight after work. But even with no security enabled, the HD200 times out when I try to enable the wireless connection, so there's something happening before my router is involved.
The IP is static, but it doesn't matter when I try to enable the wireless connection. It works fine when wired, but since it can't configure a wireless connection, the IP when wireless is enabled remains 0.0.0.0. It seems like the HD200 can't properly utilize the wireless adapter to make a connection. I'll check the router log, but I'm expecting it not to list any connection issues, since it seems like the HD200 isn't able to even attempt a connection. |
If you're willing to try this. Set your wireless security to disabled and then pull the power on the HD200. My encryption setup made it difficult to connect.
B
I've already tried it with no security enabled.
Connect a USB keyboard to the HD200 to ensure there are no mistypes or Upper/lower case problems.
Did you hard power cycle the HD200? Mine didn't work until I did.
B
I'm wondering if your firewall on your router isn't blocking the port. I know that I had to add a NAT on my router for the HD200, but I'm at work and can't tell you the ports I opened. I'm sure someone can tell me if I am full of it.
Good Luck! I know how frustrating it is! Joe. |
B
Then I'll try WPA Only mode, but I hope future firmware will support WPA2, because I'd rather have it on WPA2 Only.
The ABC 1234 or whatever button in the lower right also does it. Hit it twice to switch from CAPS to lowercase.
![]() - Andy
I don't know why I didn't think about connecting a keyboard last night. Would've saved me a lot of time.
Would the HD200's system information show its version of Ralink's adapter driver? My Windows 7 Ultimate 64-bit came with 3.0.1.0. The latest (for Win7) is 3.0.3.0, but I didn't have to install any drivers for the adapter to work on my main computer.
I can try WPA Only mode, but it times out even with no security, so I have to blame the HD200. Is there any way to update the Ralink driver on the HD200 via a flash drive? |
Another thing to try is to check to make sure your router isn't set to only the 5GHz band. The adapter only supports 2.4GHz mode....although I'd think it wouldn't even be able to see it if that was the case.
If you're still having issues; please submit a support request.
SageTV is trying to get me in trouble | Radar | The SageTV Community | 2 | 08-22-2008 05:47 AM |
QAM trouble | uberliberal | Hardware Support | 3 | 02-10-2008 10:52 PM |
Import Help - trouble using more than one | malbec | SageTV Customizations | 0 | 06-05-2007 05:55 PM |
Anybody else having trouble board? | stanger89 | General Discussion | 4 | 06-13-2004 07:28 PM |
IR Blaster Trouble | ftlee | SageTV Software | 11 | 07-19-2003 05:49 AM |
