Universal Remotes MRF-350 and HD-300
I just got my HD-300 in today and I love it. Navigation on this thing is lightning fast compared to the HD-200.
I'm also very happy that I did not need to reprogram the remote. So, I have an MX-450 w/ MRF-350. The HD-200 was fairly easy to setup as medium sensitivity and the blaster in the middle of HD-200 was perfect for me. I'm not having the same luck w/ the HD-300. Going by the blinking blue light, it looks like it is over-saturating the IR even turned all the way down. I tried moving the blaster around slight off to the IR receiver on the HD-300 and still the same. The setup is not bad, it's just not nearly as fast and responsive as the hauppage remote it comes with. I would say it's about half the speed. Has anyone else had any luck w/ the setup? Any suggestions on placement? Thanks, Peter |
FWIW - I am using a mix of Atlas5 and URC-6131N remotes with HD300s and they seem to be fine.
B
Running SageTV on unRAID via Docker Tuning handled by HDHR3-6CC-3X2 using OpenDCT |
Best universal remote? | ericscottf | Hardware Support | 49 | 07-06-2010 09:46 AM |
Universal remotes | SageGk | Hardware Support | 53 | 04-13-2009 03:41 PM |
HD 200 and universal remote | swats | SageTV Media Extender | 3 | 03-07-2009 05:48 PM |
Using a universal remote control | mmac911 | Hardware Support | 2 | 12-13-2006 07:21 AM |
Universal Remote with SR | dkardatzke | SageTV Recorder Software | 1 | 03-21-2003 03:48 PM |
