Old 02-19-2006, 01:24 PM
davidjevans davidjevans is offline
Lost control of Hauppauge remote
Hi -- just did a clean reinstall of the latest beta on an MCE 2005 machine. My 34-button Hauppauge remote no longer works correctly in Sage. When I press the up and down buttons, the highlight just jumps from the first to the last entry on any given menu; none of the rest of the buttons do much of anything.
I had this problem before on a previous install, but can't remember how I solved it. Any suggestions?
David Evans
Old 02-19-2006, 01:44 PM
Para Para is offline
Maybe check the irremote.ini file (in windows directory) and see if it was replaced/changed/corrupted. If you kept a backup of your old one you could just replace it and see if that is your problem.
-Just a guess since I don't have a MCE machine
Old 02-19-2006, 02:04 PM
... and check this FAQ entry for getting it working again.
Old 02-20-2006, 07:10 AM
That worked -- but only for a moment. Replaced the ini in Windows, rebootted and restarted, and the remote worked normally.
BUT as soon as Sage goes into standby, either manualy or automatically, the remote stops working properly again
Doesn't seem to be a beta issue because my previous installation of the same beta didn't do this
David Evans
Old 02-20-2006, 10:43 AM
If SageTV is sleeping in screen saver mode instead of in the system tray, then you'll have to edit the irremote.ini file & try removing the "{mode(Default)}" command at the end of the GRNPOWER line in the [SageTV] section. (Previous discussion here.)
Old 02-21-2006, 07:27 AM
That did it; thanks all
David Evans
