Old 12-24-2006, 02:15 PM
tooslow tooslow is offline
v6 wont play imported videos
I just upgraded to v6, and now none of my clients will play imported videos that used to play in v5 just fine. When I select play, the screen goes black, the little sage cursor comes on and the playback control ui appears on the bottom of the screen, but after a moment, the cursor stops spinning, and sage just sits there. In fact, I have to reboot the machine at this point. I can play files in the recordings drives, but nothing in the imports works. My imported videos are all in .divx format, but these used to work just fine.
Rebooting the sage server did not fix the problem.
Also, I've noticed that some times when I select play, sage minimizes to the task bar.
Old 12-24-2006, 02:28 PM
ke6guj ke6guj is offline
I don't normally run FSE mode, full screen exclusive, but I was playing with it the other day and saw some of that behaviour. Turned it off and it was back to normal. Maybe that is it.
- Jack
Old 12-24-2006, 05:37 PM
No, turning off FSE did no good. I also installed the NVidia decoder and tried that, no luck.
