Old 04-07-2007, 10:36 AM
rnewman rnewman is offline
will not play home dvds from network storage
IF I do not enable/run sagetvservicecontrol.exe I can play
my home movies/mp3/pictures from my network storage.
Network storage computer has full sharing and I have mapped
it on sagetv server computer.
Here is what it looks like in properties:
seeker/archive_directory=\\\\AMD2700\\Media\\Video,1;\\\\AMD2700\\Media\\Music,2;\\\\AMD2700\\Media\\Pictures,4;
Works great until I turn on sagetvservicecontrol.exe
Then sagetv or mediamvp or TV client on another computer
gives me the following message:
There was an error playing Steve&Win:
ERROR (-2): Files selected for playback are no longer on disk
I am running 6.1.8.0
HELP!
Ray
Old 04-07-2007, 10:56 AM
If you're running the service, you need it to be run as a user (not the default LocalSystem) to access network resources.
Old 04-07-2007, 12:53 PM
I have NEVER ran users on any of my winxp
So I install/run winxp as admin, never login/change users
looking under:
documents & settings
Admin
all users
default user
local service
Ray
my desktop is under "Ray"
Please explain!!!!
Ray
Old 04-07-2007, 04:28 PM
see final solution in thread:
"Can't import network drives"
Old 04-07-2007, 09:41 PM
Fastrack Fastrack is offline
Send a message via ICQ to Fastrack
looking under:
Admin
all users
default user
local service
Ray
Please explain!!!!
Ray
FInd the Service for Sage TV... And go to the "Log On" tab, to access network drives the Sage service can not be set to "Local System account"... this is a special system ID. Just pick "This account" and enter either.. "Admin or Ray" and the password... It should work once you do that.
Old 04-08-2007, 02:31 AM
Thanks, I am slowly understanding.
Ray
Old 04-08-2007, 03:10 AM
So to use network folders/drives for imported media.
the solution comes down to:
when customer runs SageTV Service Control he must "Change User"
to a user (current or otherwise) with a user with password
IE: Run Service As User: .\xxxxxx
NOT: LocalSystem(Default)
That is simple enough!
Ray
Old 04-08-2007, 06:47 AM
Ray
Yep you are correct!... It's not just Sage either.. It's any service which requires Network access.
DVD's not playing MVP..please help garyellis SageTV Beta Test Software 10 11-20-2006 12:18 PM
Routing file transfers on home network popechild General Discussion 8 11-11-2006 09:41 AM
MVP Blinking black screen + Sage "booting up" screen. XSiVE SageTV Media Extender 120 10-20-2006 06:36 PM
Network Storage ben_gb SageTV Software 6 07-07-2003 11:41 AM
