Old 04-03-2008, 07:58 PM
jusjoken jusjoken is offline
Play AVI file from DVD drive
I am in the middle of one of my first tweaks to SageMC using Studio and have a number of successful changes so far. However, I am new to this and can't get something that seems like it would be simple to work.
The premiss... I have either 1 or 2 (multiple) AVI files on a DVD. I have created a customized "Play Other File" menu item in My Videos that will play a file from the "sagemc/dvd_drive_letter" drive when I select this new menu item. However, I have the file name hardcoded in a string.
I want to be able to....
1. Get a list of files in the root of the DVD drive (I have the drive letter from the property)
2. if there is only 1 file... get the file name and then play it (I have the code already working to play the file once I have a file name)
or
2. if there is more than 1 file then use the browser to list the files (I can get the browser to work but I can't get the file list and count to work)
Help
Ken
Old 04-04-2008, 11:54 AM
I guess I just needed a little more patience.... I now have this working
Old 04-04-2008, 01:02 PM
CollinR CollinR is offline
You might consider adding the drive as an import directory, then it;ll just work like any other source.
You will need to refresh when you change disks though.
Old 04-04-2008, 03:34 PM
Thanks for the suggestion. My refresh takes too long for this solution to be convenient. With the code change I made, I just import my STVI and I have a new button that just plays the single AVI file that is in the DVD drive, or if there are more, it opens a browser on that drive and lets me pick. I may also play with the "Play DVD" function to do the same thing if the DVD is not a standard DVD... but perhaps that is the next project.
Sure nice to have such a customizable application.
Video file formats SageTV can use to play video DMBinbc SageTV Software 5 06-14-2007 01:10 PM
issue playing DVD craigap SageTV Software 7 01-25-2007 04:20 PM
HDTV Network Encoder v0.9.0 07-08-05 - HD Support for Sage! Stealth1971 Hardware Support 292 02-23-2006 11:40 AM
STV: Cayars17 Ultimate STV (Release 17 - Jan 18) Cayars SageTV Customizations 3664 12-13-2005 05:35 PM
