Old 10-30-2010, 07:48 PM
timg11's Avatar
timg11 timg11 is offline
New type of HD-PVR failure
Today, I noticed a new failure of the HD-PVR. While recording a show, the HD-PVR blue LED lighting, and red recording LED were blinking on and off, fairly regularly about once a second.
There was no Sage System Message posted.
I played back the show that was recording, and consistent with the recording cycling, the playback was broken into short discontinuous segments.
I'm using HD-PVR drivers 1.5.6.1 if that makes any difference.
Has anybody else seen this? It is completely new to me. Usually, when it fails, it just stops working.
I'm installing .22 now - don't really expect it to make any difference though.
Sometime in the last few beta builds, I think there has been a regression in HD-PVR reliability.
HD300 extender with (2020 New Build) SageTV 64 bit V9.2.2.903 (service mode), Running on Windows 10 (64 bit), Intel Core i7-10700K CPU, 16G RAM, GIGABYTE Z490 UD motherboard. NVidia GTX1650 Super; Viewsonic LCD on one output and Mitsubishi WD57734 HDTV via DVI/HDMI on other output. HDHomeRun HDHR5-4US tuner, Hauppauge "Siena" 1512 HD-PVR2 connected to Cisco Cable modem from Spectrum, tuned with USB-UIRT.
Old 10-30-2010, 08:19 PM
I would really recommend upgrading to the latest drivers for the HDPVR. I've not had any issues with my HDPVR and the newest drivers while running v7 on any beta version.
Were you having any reception issues with your STB today by chance? That can wreak havok on the HDPVR.
Another (possible) WD HD failure hemicuda Hardware Support 6 02-26-2007 06:29 PM
What can cause this type of image problem? carlgar SageTV Software 1 06-05-2006 01:46 AM
What type of chipset are you using? BBCritical Hardware Support 6 03-03-2006 06:09 PM
help:upgrade failure 2.0-2.2 cragis SageTV Software 3 04-09-2005 12:43 PM
