Old 09-11-2022, 06:35 PM
jqweber jqweber is offline
Device support...
I currently have 2 old Hauppauge HD-PVRs running fine. I am looking to add one of these - either:
HD PVR Rocket
or
StreamEez-Pro
Can't seem to find verification on the forum that these will work.
Anyone know whether or not these will work with Sage?
Old 09-12-2022, 04:14 PM
KryptoNyte's Avatar
HDPVR Rocket:
https://forums.sagetv.com/forums/showthread.php?t=60898
I can't answer for the StreamEez-Pro.
The general direction folks are going with this type of application is network encoders:
https://forums.sagetv.com/forums/showthread.php?t=63177
The network encoders typically input virtually any incoming HDMI signal, encode it on the fly, then present it to your home network (via ethernet) and SageTV can then access the encoder video stream(s).
Virtually all of these solutions are stereo only audio.
What cable/satellite service are you trying to get into Sage?
Old 09-12-2022, 05:18 PM
Xfinity.
Working fine on my 2 HD-PVRs; Windows 10.
Most interested in the Rocket since it is USB-powered (no wall wart).
Old 09-12-2022, 05:48 PM
KryptoNyte's Avatar
The Rocket appears to be a no-go for SageTV.
Old 09-12-2022, 05:52 PM
KryptoNyte's Avatar
Just out of curiosity, (forgive me for the plug here, because I am a die-hard SageTV user) have you considered a trial of Channels DVR with Xfinity TVE (TV Everywhere)? It could be a bit more volatile than what you are used to, but it doesn't require any hardware tuners, and you don't really have a limit on the number of tuners. Additionally, a few users here have managed to get a combination of Channels DVR and SageTV working.
https://community.getchannels.com/t/...-xfinity/18118
You may still need an antenna with an HDHR tuner to receive your local stations in a manner that you like.
Old 09-12-2022, 06:06 PM
I was not aware of this Channels DVR thing.
I will check it out.
Thanks for calling it to my attention!
EMBY add direct support HDHomerun support SHS General Discussion 24 06-10-2015 05:37 PM
Using Motorola Tuner device for capture device cyberfreak Hardware Support 4 02-22-2007 02:47 PM
No AV Capture Device jaelanicu SageTV Recorder Software 5 08-03-2006 02:02 AM
sound device jsturtevant SageTV Software 1 08-03-2004 10:42 AM
Possible new device for using UK Sky EPG Xleon General Discussion 0 05-27-2003 03:19 PM
