Old 02-06-2019, 07:38 AM
brandypuff brandypuff is offline
Plugin Updates: FAILED - Resource download
There are several plugins that aren't updating due to FAILED - Resource download errors. How do i fix this?
- James M -
Server: Asus P5B Deluxe, 8GB, Core2 E6600 @2.4GHz, Windows 10 X64 Pro
Storage Internal: (1) 250GB, (2) 2TB, (1) 4TB
Storage External: Sans Digital 4-Bay eSATA Port Multiplier RAID Enclosure with (4) 4TB Drives
Capture Devices: HDHomerunXTEND, HDHomerunPrime
Clients: (1) STX-HD100 HD Media Extender, (3) HD200 HD Theatre, (1) HD300
Old 02-06-2019, 07:56 AM
jusjoken jusjoken is offline
Post a log after trying the update so we can review the errors.
k
Old 02-06-2019, 08:03 AM
not to be ignorant, but which log? I see sagetv logs everywhere.
- James M -
Old 02-06-2019, 08:57 AM
graywolf's Avatar
graywolf graywolf is offline
The sagetv_#.txt file that covers the time period in question
Old 02-06-2019, 11:30 AM
Tiki's Avatar
Tiki Tiki is offline
Iím not positive , but thereís a good chance this related to your Java version. Itís my understanding that many of the download sites moved from http to https (secure) connections. Older versions of Java didnít support this. I think you neeed Java 8 or newer.
,USBUIRT (multi-zone)
Source:
Comcast Cable
HDHR, HVR-2250
Old 02-07-2019, 09:39 AM
That's exactly what it was. After i upgraded to Java 1.8, i could update the plugins. Thanks.
- James M -
External BD/DVD plug-in download failed UgaData SageTV v9 Customizations 8 09-26-2018 07:18 AM
V9 Plugins - Failed Resource download? brandypuff SageTV Github Development 7 07-17-2018 08:51 PM
Plugin failed Doubledose SageTV v7 Customizations 4 03-30-2014 10:56 AM
Jetty download failed, BMT won't install farscapesg1 Batch Metadata Tools 2 11-28-2011 09:50 AM
