Old 03-30-2019, 03:03 AM
jughead's Avatar
jughead jughead is offline
Question Where is screensaver image stored?
Hi, I'd like to change the bouncing SageTV logo that comes up for the screensaver to another image. I'm assuming I can just swap it out with another of the same size.. but where is it located??
Thanks in advance!!
Old 04-01-2019, 08:10 AM
graywolf's Avatar
graywolf graywolf is online now
Detailed Setup.
Think Advanced has Screensaver options or maybe Customize
See if that works for you
Old 04-01-2019, 12:05 PM
wnjj wnjj is offline
I believe it's:
based upon what the STV is calling out.
That image is probably used for more than just the screensaver though. If you want a unique one just for the screensaver you may have to modify the STV.
Incorrect image stored when scraping media files jpaddock3000 Batch Metadata Tools 5 08-18-2011 01:12 PM
MyMovies Image folders DO NOT MATCH SMM Extender Image Folders? emotionnotion Sage My Movies 8 08-27-2010 11:35 AM
Recordings preview image showing the same (wrong) image dinki SageTV v7 Customizations 4 07-12-2010 04:35 PM
Screensaver on Sleep karnal SageTV Software 1 11-02-2008 05:02 AM
Passing image name from action to image widget jbuszkie SageTV Studio 5 12-09-2005 07:40 PM
