SageTV Studio Discussion related to the SageTV Studio application produced by SageTV. Questions, issues, problems, suggestions, etc. relating to the Studio software application should be posted here. |
I've been inspired, I'm trying to redo the main menu, but right now I've run into a bit of a snag. I've got an item that I'm trying to put a couple of text widgets in, and the problem is that the text widgets seem to be getting "themed", but I can't figure out where from.
Why does the subpannel not fill the Item widget? |
Alright, I suppose some ascii art to illustrate what I want.
I'm trying to build an item widget like this: Code:
------------------------------------------- | Text goes here | |-----------------------------------------| |Picture| More text here | |-----------------------------------------| | | ------------------------------------------- |
w/o looking at the actual code... how is the themed Item defined? You are adding a full-width panel to every item that the theme applies to, but the item itself may not have a defined width.
Edit -- Oh, I see. Check the Item's insets. - Andy
You should be able to use the UI Component view and then find the text widget in there and then right-click on it to get an option to view the Themed widget for it.
Very cool, didn't know that...
![]() OK, so how do I override it? It's pulling the theme from MainMenuTheme ItemTextTheme text widget. I tried putting a Text widget in my Item them, but even that get's themed by the MainMenuTheme. |
If you add a text widget to the item in your theme, then you will add a text widget to each item on the screen. If you want to theme the item's text, then you have to put a text widget under a theme widget.
OK, here's the Item code:
Item (Item Widget) \if GetElement(MenuItems, LastIndex) -\branches to navigate pages -\GetElement(MenuItems, LastIndex) --\Untitled (text widget) |
Did you check the "Insets" widget property that I mentioned above? I'm guessing that the themed Item uses Insets, like the default STV does.
I feel like an idiot.
