Old 12-24-2005, 08:02 AM
Mahoney Mahoney is offline
Is All Video Editing Software Terrible To Use?
I've just wasted about three hours trying to edit a Sage recording using AVS Video Editor. Cut out all the ad breaks, all the references to other programs, was just cutting off the extra crap at the end of the recording - and it deleted all my work so far. No undo button. No checking whether I really wanted that to happen. Just hours of work down the drain.
I suppose I should have been saving the project after each successful edit, but in this day and age I don;t expect to have to do that!
Every time I try to do some video editing using any software I find it paralysingly frustrating and unintuitive in the user interface. In four months of using Sage I have yet to archive anything to DVD because it is so ludicrously difficult and long-winded to do simple things like topping and tailing and removing adverts.
Very Frustrated!
Old 12-24-2005, 08:15 AM
dvd_maniac's Avatar
dvd_maniac dvd_maniac is offline
I do not use AVS Video Editor but the two programs that I do use is VideoRedo (For video to encode) and TMPGenc DVD Author(For videos to archive on dvd). Open the mpeg in DVD Author and it is easy to make the cuts. about five minutes, then when done burn to blank DVD.
VideoReDo has more features and does not burn to Blanks but is even easier to cut as it has an automatic Advertisement detection feature.
If this doesn't work right, Then:
"I'm going to blow up the Earth!"
Old 12-24-2005, 08:56 AM
dbfresh23's Avatar
dbfresh23 dbfresh23 is offline
I use a ShowAnalyzer to detect the commercials and output the VideoRedo project file then VideoRedo to cut them out - it doesn't get much better then that. I have found that SA has been spot on every single time I've used it and it required no further editing in VideoRedo.
Old 12-24-2005, 10:40 AM
shodge's Avatar
shodge shodge is offline
VideoRedo
VideoRedo - It does not get any beter or simpler. You can edit by hand frame by frame or use the auto stuff. Just try it....
-Stan
Old 12-24-2005, 08:15 PM
Menehune's Avatar
Menehune Menehune is offline
I love VideoRedo. Unfortunately, most video editing software has a steep learning curve and can take a long time time to learn.
I have one folder where the "raw" mpegs are stored, then a second folder where the saved movies are saved to. When I save them, I usually remove the "garbage" at the end of the file name.
Old 01-24-2006, 03:11 AM
Just wanted to say a big thanks to all those who recommended VideRedo - using it myself now, and it's great. Really easy to use. Thamks a lot.
Old 01-24-2006, 04:56 PM
Polypro Polypro is offline
Originally Posted by dvd_maniac
I do not use AVS Video Editor but the two programs that I do use is VideoRedo (For video to encode) and TMPGenc DVD Author(For videos to archive on dvd)...
Ditto!...'cept I went with Womble
P
Old 01-26-2006, 09:11 AM
TripleTapper TripleTapper is offline
Video Redo is amazingly simple to use. My only complaint is how long the auto commercial detect takes....I can do it manually quicker then the auto feature (12 min for 1/2 hour program). I also don't understand why it takes so long to save the finished project. Does SA detect commercials any faster? Obviously since Video Redo is the "standard" on this forum, you guys must not be put off by the slowness....I may be out of luck. Oh well, still better then what I had!
Old 01-26-2006, 09:57 AM
MrApollinax's Avatar
MrApollinax MrApollinax is offline
Send a message via ICQ to MrApollinax Send a message via AIM to MrApollinax
I think it may be your setup. It literally takes a few minutes for the entire editing process for me. Are you trying to edit a file over a network? I can see how network latency would cause the slow down you are seeing.
SageTV Server: Windows XP Pro SP2, 3 GHz DC processor, 2 GB RAM, 256MB GeForce 6800, Plextor ConvertX PX-TV402U, Hauppauge 150MCE
SageTV Extender: Hauppauge MediaMVP
SageTV: 5.0, Comskip STVi, Standard Interface
Router: Dlink DGL-4300
Using Wireshark to Troubleshoot Network Issues with your SageTV Setup
Ignore my last post. I haven't tested it yet, but I think I kno what my problems are. I was testing out Video Redo on a laptop over a wireless connection. Tonight I will run it on the Server and I bet the video dectection will go a LOT quicker
Old 01-27-2006, 02:16 AM
mayamaniac's Avatar
Recently tested videoredo, amazing app.
whats better, womble or videoredo? Does womble have ad detection? Does womble author to DVDs?
Also can you output SA cuts to womble?
Mayamaniac
Old 01-27-2006, 02:33 PM
SHS's Avatar
SHS SHS is offline
No but then YES depend on which one you have, MPEG Video Wizard you can loading BTV cut list XML (chapters.xml) file in the bookmark manager.
Be side AdDetective or Commercial Detection is not 100% and I fine it be waste of my time in long run with VideoReDo and MPEG Video Wizard.
This Yes but not N/A rigth now it under Private Beta Testing.
What SA cuts mayamaniac
There are lot things that VideoReDo can't do that MPEG Video Wizard can but keep mind it depend which womble tools you are ref to.
Old 01-27-2006, 03:12 PM
mayamaniac's Avatar
Someone above said they use ShowAnalyzer to detect the commercials and Videoredo can import it and cut the commercials out based on the SA commercial detection. I suppose this is not possible with womble since it only support XML data from BTV?
I guess the next question is whether SA can output to XML or something Womble supports.
Mayamaniac
Old 01-27-2006, 03:23 PM
KJake KJake is offline
SA will output boths formats that Womble uses and I use it all the time for cutting commercials out.
Old 02-14-2006, 04:40 PM
korben_dallas's Avatar
korben_dallas korben_dallas is offline
Looking at the VideoRedo site, I don't see options to re-encode. Can it do this?
What I want is to re-encode my mpeg-2 shows to various different formats.
SageTV server & client: Win 10 Pro x64, Intel DH67CF, Core i5 2405s, 8 GB ram, Intel HD 3000, 40GB SSD system, 4TB storage, 2x HD PVR component + optical audio, USB-UIRT 2 zones + remote hack, Logitech Harmony One, HDMI output to Sony receiver with native Intel bitstreaming
Old 02-14-2006, 06:08 PM
dbfresh23's Avatar
Only options I see for VideoReDo Plus is just saving as MPEG, VOB and TS, no re-encoding.
I use WinAVIVideoConverter to do most of my converting, it can convert to just about any format you can think of - Divx, XVID, WMV, MPG, DVD, RM, VOB... It can also do batch converts.
