Old 07-17-2007, 05:39 AM
marklp77 marklp77 is offline
Question 2 tuners, one cable box.....
I have two tuner cards. I would like to hook up one to a cable box controlled by a RF Blaster. The other one would just connect directly to the analog feed. My concern is how will SageTV choose tuners when I set it to record a show that requires the cable box feed. Will it know what tuner to choose?
Old 07-17-2007, 09:08 AM
Just to make sure, you mean an IR blaster, right? I don't think there are any RF blasters (and I think people have mentioned some RF controllers).
When the sources are configured, the one connected to the box will be configured as using an external receiver & a blaster, so SageTV will know to use the blaster when it needs to record something using that tuner.
Also: when you configure them, they will need to use different channel lineups so that you can have different channels enabled for each one.
Old 07-17-2007, 10:14 AM
Excellent, Thanks (yes, I did mean "IR" Blaster..)
Cable signal quality issues -- do I need an amp? null_pointer_us Hardware Support 8 02-26-2007 05:19 PM
Need another tuner card and ability to control cable box ybrew Hardware Support 15 08-01-2006 09:25 AM
Tuning SD digital cable without a cable box null_pointer_us Hardware Support 16 07-19-2006 08:46 AM
Sagetv confused about changing channels through tuner or cable box vmadahar Hardware Support 7 07-10-2006 12:14 AM
After upgrading to Sage 4.0 cable box channels don't change MSquid Hardware Support 3 12-12-2005 10:59 AM
