Old 09-14-2007, 09:34 PM
BarkOLounger BarkOLounger is offline
Library DVDs on Main Menu
I know that there is probably a way to do this and posts on how, but I've looked and I can't find it. So I'm hoping that someone who know will answer me.
Instead of having to click on media center, imported videos and then DVDs I just want to have a menu option called DVDs on my main menu in Sage. I've not been able to find an STV that does this (probably haven't looked hard enough so apologies in advance if that's the case).
I've tried to get it to show up as an alternate view, but that won't seem to work.
Any advice or help would be greatly appreciated. I'm running 6.2.6 right now.
Thanks in advance!
Chris
Old 09-14-2007, 09:43 PM
Check the dynamic menus import for a way to be able to add/edit items on a menu. There might be an example in its thread about how to jump to a specific media browser view. (Or you could use Studio to add a menu item.)
Edit: If you add your own menu item in Studio, you can add this line before jumping to the "Browser - Videos" menu to have it start on the DVD view:
AddStaticContext("newVideoBrowserStyle","xDVD")
Old 09-15-2007, 03:08 AM
nielm's Avatar
nielm nielm is offline
http://tools.assembla.com/sageplugin...uleDynamicMenu
This pasteable menu item contains a menu with all the views -- just copy/paste the one you need..
http://tools.assembla.com/sageplugin...rviewssagetvv6
Old 09-17-2007, 03:03 PM
Thanks to both of you for your quick and helpful answers!
DVD menu indicators missing while plaing DVDs via Sage ripple SageTV Software 5 12-19-2006 12:48 PM
STV Import: Weather Monitor deria SageTV Customizations 35 08-23-2006 08:15 PM
Link Animations to Menu Items? jagee23 SageTV Customizations 2 07-24-2006 07:03 AM
Customizing the Main Menu? snoopy SageTV Customizations 3 07-26-2005 04:13 AM
