General Discussion General discussion about SageTV and related companies, products, and technologies. |
Disable or uninstall MCE in Vista?
I have the Gyration remote and have disabled the MCE services (as found in the MCE Remote for Sage thread) but it still gives me problems. When I click on the "guide" button it goes to SageTV's guide...but then still launches MCE, although now you just get a blank screen you can't get out of without shutting down MCE through task manager.
Does anyone know of a way to just remove MCE from Vista? |
I'm not sure in Vista if it's called the same but that is the ehtray.exe process that is doing that. You would need to stop that process from running-it's not a service. AFAIK MCE is not an installable/uninstallable app.
I have the same Gyration Universal Remote, it was a great choice. I had the same problems you did with using it with Vista Ultimate. This following thread is what I used to fix those issues with the remote.
http://forums.sagetv.com/forums/show...ighlight=vista In Particular Hope this helps, Protoman
Server: Synology DS1019+, 2x WD Red 10 TB, 2x HVR-950Q OTA Old Server: ASRock Z77 Pro5-M, Intel i3-3225, 16GB RAM, 2x HVR-1800 OTA, 2x HVR-950Q OTA, 2x HD-PVR w/SPDIF (Not in use), 2x 1TB WD Black, 2TB WD Black, and Windows 7 Professional 64-bit. - 1x HD 300 - 2x HD 200 |
Cool thanks. I just ran MMC on my laptop to test it and I don't know where to load the group policy object editor from.
NM, found it (File - Add/Remove Snap-in).
You can type in gpedit.msc in the Run box to go right to the group policy editor.
Note that gpedit is not available on Vista Home versions...
Check out my enhancements for Sage in the Sage Customisations and Sageplugins Wiki ![]() |
Since gpedit isn't available on Vista Home Premium, does anyone know of a way to disable the ehtray.exe process without gpedit?
SageTV v6.4.5 - Windows Vista Home Premium HP m8200n, Athlon 64 X2 6000+, 3GB RAM, 3 500 GB SATA/300 7200 RPM HDD's (2) PVR-150MCE's - (1) HVR-1800 HD ATSC/NTSC - (2) MediaMVP's - (2) STX-HD100's |
I have the same problem. Anyone worked out how to do it It appears that even disabling ehtray.exe using msconfig does not work as when you press the green button, the services get started nayway!
Setup: - Server - Intel 3.4G D + XP, 2Gig ram, 3TB of raid. All running in service mode with 2 Hauppauge HVR4000 Running v7 with LMGestion's XMLTV and DG2XML. I also have the web server running. Client - x2 plus PlaceShifter on various machines including eeepc Ubuntu 8.04. I am streaming Live TV to my PocketPC. Stable but can use DVB-S on second HVR400. ![]() |
I renamed the ehome directory in Windows to ehomeold. So none of the Media Center stuff works.
USB-UIRT + MCE Remote | jblaty | Hardware Support | 3 | 07-09-2007 01:52 PM |
How can I use my new MCE remote control which came with my Vista PC for SageTV? | mkanet | Hardware Support | 3 | 06-23-2007 07:55 AM |
Need to Fully Disable MCE | Sandbox | General Discussion | 1 | 11-12-2006 05:13 PM |
SageMC - Stop button causes AWTThread Hang | Mahoney | SageMC Custom Interface | 7 | 10-25-2006 12:47 AM |
MCE2005 = Sage 2.0 killer? | rotaryracer | General Discussion | 45 | 10-27-2004 06:50 PM |
