Sage Pro Theme V0.08 for Standard STV V6.3
A loadable UI theme for the Standard STV. Requires SageTV V6.2 or later. Also designed to be used with neilm's Dynamic Menu 6.3 (First version with Themes. Tested and developed with 6.3.6 RC.) Installation Unzip the package into your Program Files\SageTV\SageTV\STVs\SageTV3\Themes folder. In Dynamic Menus remove any paths that may be in there for the icon paths. Make sure you just leave the default name of the icons. (example: mm_recordings.png. You can either find and replace in the menu's xml file or remove it from within Sage and the Dynamic Menu options.) In SageTV, go to Setup > Detailed Setup > Advanced > Select the User Interface Theme and choose SagePro HD720 (for 16x9 displays) or SagePro SDTV (for 4x3 displays). For support or suggestions, see this forum thread here. Screenshots ![]() ![]() ![]() Shades of Meedio Yes I know some will recognize it from my Meedio Pro theme I did long ago. Icons Icons were originally created by Paul Davey. He originally did the GANT icons that are included with the Dynamic Menu plugin. According to the documentation included with the icons: Quote:
New Main Menu Icons! (more to come) Almost every other icon is replaced! New busy/wait cursor! All new Weather icons! You can download the theme from here. I'm still working on some issues but felt it is in shape to play with. This is a work in process and as new features are added to the core and Dynamic Menus they just may be used by this theme. If you have questions or comments put them in this thread. NOTE: Make sure that both the SagePro SDTV and the SagePro HS720 folders are located in your theme folders. One is dependant upon the other for its base icons and weather icons. Gerry
Big Gerr _______ Server - WHS 2011: Sage 7.1.9 - 1 x HD Prime and 2 x HDHomeRun - Intel Atom D525 1.6 GHz, Acer Easystore, RAM 4 GB, 4 x 2TB hotswap drives, 1 x 2TB USB ext Clients: 2 x PC Clients, 1 x HD300, 2 x HD-200, 1 x HD-100 DEV Client: Win 7 Ultimate 64 bit - AMD 64 x2 6000+, Gigabyte GA-MA790GP-DS4H MB, RAM 4GB, HD OS:500GB, DATA:1 x 500GB, Pace RGN STB. Last edited by gplasky; 01-20-2008 at 07:49 PM. |
Thank you, trying it out now.
B Tried it out. The background image needs to be renamed to Background.jpg to work on Linux, and I assume Mac. Thanks again! Edit 3 - It's a no go for me, the weather icons with the silhouettes is a deal breaker.
Running SageTV on unRAID via Docker Tuning handled by HDHR3-6CC-3X2 using OpenDCT Last edited by bcjenkins; 01-20-2008 at 08:43 PM. |
Nice work!
![]() I haven't found any issues with it so far... -Robert |
Help me understand why the weather icons with the silhouettes is a deal breaker. I don't have issues on the MVP, HD Extender or any PC client. PS-I've taken nothing into consideration for running on a Mac or Linux. Gerry
[sagetv@sagetv-server Standard HD1080]$ cat ../../SageTV3.xml |grep background.jpg [sagetv@sagetv-server Standard HD1080]$ cat ../../SageTV3.xml |grep Background.jpg <Action Name="ImageFile = "Background.jpg""> [sagetv@sagetv-server Standard HD1080]$
Running SageTV on unRAID via Docker Tuning handled by HDHR3-6CC-3X2 using OpenDCT Last edited by bcjenkins; 01-21-2008 at 11:22 AM. |
Thanks for the effort here. Running 720 version on large screen and looks great. Nice job
B
Running SageTV on unRAID via Docker Tuning handled by HDHR3-6CC-3X2 using OpenDCT |
I just want to say thanks for this theme - I've been using if for a while and both my wife and I much prefer it to the stock theme.
Thanks! Matt Last edited by mcaron1234; 06-08-2008 at 08:20 PM. |
This is great. Thanks!
Thanks for this. A bit zippier than what SageTV supplies.
Getting Sager all the time... Displays: Panasonic 65" P65S2 & 50" PX77E plasmas, 19", 26" & 32" LCDs, 4 HD200s Source: 2 HD-PVRs, Rogers Toronto SA 8300HD PVR, 4250HD firewire tuned, WHS, SageTV, Sonos 1xZP100 & 3xZP120 wireless audio, Gigabyte GA45-E45-UD3R mobo, 2.5 GHz Core 2 Duo E5200 (2MB L2), Nvidia GeForce 96400GT, 120GB OS drive, 1 & 1.5 TB WD Caviar Green, Mushkin 2GB DDR2 800 SDRAM, El Cheapo case, Corsair 520HX modular Power Supply. |
Extra info at bottom?
Thanks! Just downloaded and working with the 720 version. How do you get the extra info to show at the bottom of the main menu?
Simple (but effective) security for any STV | Lester Jacobs | SageTV Customizations | 5 | 12-17-2010 03:21 PM |
WMA Pro 5.1 plays as stereo in Sage... | travisbell | SageTV Software | 0 | 04-01-2007 11:53 AM |
STV: Cayars17 Ultimate STV (Release 17 - Jan 18) | Cayars | SageTV Customizations | 3664 | 12-13-2005 05:35 PM |
MCE2005 = Sage 2.0 killer? | rotaryracer | General Discussion | 45 | 10-27-2004 06:50 PM |
