Old 06-23-2008, 06:57 PM
zazz zazz is offline
Channel Changing Problem
I am running sagetv 5.04. I recently reinstalled and I have seemed to have developed a problem using the remote to enter in channel numbers. Basically, when in the programming guide and trying to enter in a channel number for example say 500, the guide accepts the 5 then 0 and automatically moves the guide to channel 50. I did a bit of research in the forums and added this line to my properties file ui/channel/max_digits=4,but no change. I'm not sure what other options there are available to change. Anyone have any ideas what the problem might be?
Old 08-09-2008, 08:25 PM
timnelsonic timnelsonic is offline
I had a similar problem and got some improvement by messing with the timing of the channel changes. See this thread. It didn't solve my issues but it did help. I think I need to do some more experimenting. Hopefully this helps you.
SageTV Digital Analog Channel Conflicts OldPCGUY SageTV EPG Service 8 02-13-2008 11:06 AM
problem transcoding one channel with 6.1.8 ldavis SageTV Software 1 04-10-2007 09:54 PM
USB-UIRT & DCT6412 channel change problem johnnyspo Hardware Support 4 01-18-2007 09:27 AM
channel tuning problem gand SageTV Software 0 11-03-2006 12:53 PM
Version 6 Channel Changing Issue mike1961 SageTV Beta Test Software 12 10-13-2006 03:23 AM
