Old 07-21-2008, 08:58 AM
sdsean's Avatar
sdsean sdsean is offline
Question HVR-950 and Clear QAM
Hey Everyone:
The Sage website doesn't list Hauppagues's HVR-950 as a Clear QAM capable HDTV tuner.
Yet the HVR-950 is indeed a Clear QAM capable device and works within Hauppague's own WinTV software.
Is there a way that I can Sage to work with the HVR-950 for Clear QAM?
AMD Ryzen 9 3900XT 12 Core+HT, 64GB DDR5, GeForce 1060, MSI Prestige x570 Creation Mobo, SIIG 4 port Serial PCIe Card, Win10, 1TB M.2 SSD OS HDD, 1 URay HDMI Network Encoder, 3 HD-PVR, 4 DirecTV STB serial tuned
Old 07-21-2008, 09:55 PM
sdsean's Avatar
uh, no-one?
Old 07-22-2008, 09:43 AM
sic0048 sic0048 is offline
So you have tried it in Sage and it doesn't work? What exactly happens? Does it find the tuner at all?
Check out this thread since several people have gotten it to work with Sage. It may appear as a HVR-980 inside Sage for some reason, but it seems to work.
Good luck.
SageTV v9 (64bit)
OpenDCT
Using CQC to control it all
Old 07-22-2008, 10:04 AM
sdsean's Avatar
thanks, i posted a question over in that thread. . .
its just bugging me b/c the Hauppauge software works with it just fine for clear qam. It just does a clear qam channel scan and comes up with everything brilliantly. . .
one question i have is, in the setup wizard you select
Digital TV -> Cable / Satellite or Local OTA
My question is, is there away to force Clear QAM checking?
What does the setup wizard do when you have a Sage supported Clear QAM piece of hardware?
