SageMC Custom Interface This forum is for discussing the user-created SageMC custom interface for SageTV. |
Error:Unknown Internal Screen on MC Main Menu
I have been using sage for years but mostly with defaults so I'm only passing familiar with plugins and using alot of the custom features. I want to start using the netflix plugin so I have to start using the MC interface. I have done a good bit of reading on the forum but can't find anything that seems to directly address my problem. I am using the latest versions of Sage and MC.
I load MC per the instructions and everything on the main menu comes up just like the default screenshots but when I click on most the the menu items, like "SageTV Recordings" I get the error "Error:Unknown Internal Screen "Sage Recording SHORTCUTS"" I can enter the setup menu but most items on the list give me a similar unknown internal screen error. About the only things that work are the weather and Watch Live TV from which I can get to my recorded shows through submenues but its a pain and I definitely need to get to items in the setup menu to use the netflix plugin. My debug file for a short session where I click on a couple menu items and get errors is attached. Any help would be much appreciated. |
It looks like the menu.xml dynamic menus definition file was loaded, which I think may be looking for menus in the default STV. I believe the default definition file for SageMC is menu_sagemc.xml. Try loading that through the dynamic menu configuration screen (1st item on main menu options menu) and see if that helps.
Aloha, Mike
"Everything doesn't exist. I'm thirsty." ...later... "No, it's real!!! I'm full." - Nikolaus (4yrs old) |
That did the trick. I actually just moved menu.xml to a backup location and renamed a copy of sagemc_menu menu. If I want to switch back I will have to remember to copy it back.
Thanks for the help. |
STV: SageMC 16x9 Version 6.x (latest dev build) | dflachbart | SageMC Custom Interface | 6112 | 04-04-2008 11:16 PM |
Help keeps returning to main menu | Johnwhelan | SageTV Software | 1 | 03-10-2008 05:27 PM |
SageTV service takes 10-20 minutes to start | White94Cobra | SageTV Software | 0 | 11-06-2007 09:00 PM |
How to move main menu in SageMC? | fas77 | SageTV Customizations | 5 | 10-23-2006 06:42 PM |
DIFFERENT black screen -- main SageTV menu | dragon | SageTV Beta Test Software | 5 | 04-21-2004 10:34 PM |
