USB UIRT is sending double digit of the number
I am having a problem. Starting today, my USB UIRT is sending double digits of the number. For instance, if I want to tune to 842. It will see 8...8...4...4...2...2 I have restarted Sage. I have shutdown sage, uninstalled USB UIRT drivers, reinstalled them, and tried again.
Now I am using two HD PVRs. But as I said, this is a new problem. So I am not sure what is going on. Any ideas? Defective USB UIRT?
Media Server: Win 7 Home (32 bit), GIGABYTE GA-EP43-UD3L LGA 775 Intel P43 ATX Intel Motherboard, Intel Core 2 Quad Q9505 Yorkfield 2.83GHz, 4 GB Ram, Geforce 9600 GT PCI-E, 1x HD PVR, HD homerun (2x for OTA, 1x for FIOS QAM), 1 x HD Homerun Prime with cablecard from FIOS. Client: Windows 10 Pro Media Extenders: HD-200 x 3, HD-200 x 2 |
Hi. It could be that somehow the repeat count for your blaster is set too high. Perhaps you've moved your blaster or played with some of the settings.
Here's a forum post that seems to be almost the same. It also includes a solution if your repeat count is too high. http://forums.sagetv.com/forums/show...sb-uirt+repeat Good luck |
thanks for the quick reply.
I got so frustrated last night I decided to try and set up firewire. this time I was successful.
It's great that you got tuning set up with firewire. From what I understand, it is much more reliable than a blaster anyways.
Steve |
I have done a lot with PVR since 2003. I think the greatest success I felt was getting the firewire set up. It actually was not that hard, thanks to Opus. His sticky put it all in one place for the drives and resources I needed
...actually, it would have helped if Opus told me where I put the second firewire cable I have. I eventually had to go out and buy one. ![]() ![]()
IR Blaster USB UIRT not waking STB up | 2FarGone | Hardware Support | 4 | 06-11-2007 08:11 AM |
Problems controlling DEC-3000S with USB UIRT | oaamaas | Hardware Support | 2 | 04-10-2007 01:52 PM |
USB UIRT not always tuning | phunny | Hardware Support | 3 | 03-24-2007 07:51 AM |
Usb Uirt doesn´t work in Sagetv Service mode in V4 | Nadim | Hardware Support | 3 | 12-08-2005 12:32 AM |
Unable to enter double digit channels | sabre | SageTV Software | 6 | 11-15-2005 01:20 PM |
