Old 11-17-2008, 10:08 AM
m1abrams's Avatar
m1abrams m1abrams is offline
Playing back Bluray, how do you do it.
Mod if this should be in another spot please move it, was not sure where best to put this topic.
So I have been using PowerDVD8 Ultra to play back my Blu ray movies just fine until recently. Went to play "The Incredible Hulk", well PowerDVD popsup saying I need to update it. SO I did. Well after the update I go to play the movie and I get the Error 0110, which is complaining that it can not ouput on my digital interface (HDMI) because it is not HDCP. Well when I run BD Advisor I am all greens including HDCP. Hardware is a 1 year old Samsung LCD, ATI 780G based motherboard using onboard video which is HDCP compliant. Again I have not had an issue before.
Now I am not sure if the problem is from the update or if it is this specfic Bluray. I do not own any Blu ray movies just use Netflix so I do not have any to test with.
So I decided let me do the trial of AnyDVD, however after installing that. Even if it is not running now PowerDVD crashes anytime I try to play the movie. I was able to use AnyDVD to rip the movie (note plan to watch it once and then delete it both for ethical reasons and space). Problem I have is when I rip it it seems the Audio is only 2 channel?
What do other people suggest. Note I do not plan on dropping another $100 on a product that may or may not work. Cyberlinks support is horrible!
Old 11-17-2008, 11:01 AM
Jesse's Avatar
Jesse Jesse is offline
Hi M1,
I have had great luck with ArcSoft Total Media Theater. When I first tried it (several months ago) there was a free trial available that would play BD and HDDVD. If the free trial is still available I would give it a try.
Jesse
Server: Asus P5Q-EM DO, Q6600, 8 Gigs ram, WHS 2011, 1 HDHomerun(x2 OTA), 1 HD-PVR, 1 Colossus, V7.1.9 sage, 3.3 TB vid storage.
HD100 X1
HD200 X2
HD300 X1
Old 11-17-2008, 12:16 PM
m1abrams's Avatar
Hmm it does not look like they offer a trial version currently . Already stuck with an expensive piece of software that does not work (POWERDVD8)! Not saying Total Media Theater does not work, heck it is probably the best out but I will not know since I am not wasting money to find out if it works or not.
Old 11-17-2008, 12:32 PM
HelenWeathers's Avatar
Here's a place to look.
http://forum.cyberlink.com/forum/posts/list/4117.page
If this doesn't help there's a support tab at the top of the page to get help.
Live TV playing back wrong tuner... Slipshod SageTV Software 0 04-18-2008 02:21 AM
Webscheduler recordings - playing back in SageTV ero SageTV Software 2 03-27-2008 07:23 AM
When recording, in grouped playback, is over sageTV jumps back to recording menu...?? Mtlca401 SageTV Software 2 03-24-2008 04:12 PM
Stuttering back with 6.1.3RC MTuckman SageTV Beta Test Software 5 02-21-2007 01:44 PM
playing back media files to my TV ViAo SageTV Software 4 10-21-2006 01:49 PM
