Old 01-15-2011, 11:20 AM
jorton jorton is offline
If I touch my HD300 while it's on (blue light), it turns off (red light)...
Just curious if this is a feature of the HD300 or something
I know there are a lot of "touch" sensitive buttonless devices out there that do similar but was just a little worried that there was something wrong with the device.
Other than this odd little "feature" my HD300 is great. Plays back everything I have thrown at it
J
Old 01-15-2011, 12:26 PM
Apap's Avatar
Apap Apap is offline
Static discharge or bad ground?
Old 01-15-2011, 01:01 PM
MrD MrD is offline
I am encountering a similar problem where the unit will turn off immediately when I turn in on after a few days idle.
The only way to correct is to unplug from the wall and plug it back in.
[size=1]-MrD
Linux Server 7.1.9 (1)HD300 (1) HD200 (1) HD100 (2) PC Clients
Intel Xeon L? 32Gb
CetonTV cable card /FIOS
Old 01-15-2011, 01:03 PM
J
Then don't touch it.. ;-)
Old 01-15-2011, 01:51 PM
Thanks, my first solution was to wear oven mitts but I was having trouble with the buttons on my remotes, so your solution of just not touching it is way easier ;o)
Old 01-15-2011, 05:45 PM
Spectrum Spectrum is offline
<snicker>
I ordered and HD300 just before Christmas and it doesn't have this oven mitt required feature, although it is in the kitchen so maybe it would be an appropriate fit for my situation?
Does the power connector fit securely in the back of the device? It sounds like power is either getting disconnected or shorted out.
Old 01-15-2011, 08:56 PM
sverstegen sverstegen is offline
Mine will stop delivering signal randomly during playback. TV (via HDMI) says "No signal" and goes blank. Then 5 seconds or so later it recovers. I do not have this issue with any other video sources on the TV. I have also had it completely crater a couple times, requiring an unplug/plug in. Any others experiencing this?
Old 01-16-2011, 01:14 AM
MeInMaui's Avatar
MeInMaui MeInMaui is offline
You're holding it wrong....
- Nikolaus (4yrs old)
Old 01-16-2011, 02:12 PM
Probably was just holding it a little too tight as the family huddled around it to keep warm, it's cold up here in Canada ;o)
Old 02-03-2011, 01:53 AM
Blimpo Blimpo is offline
HD300 touch outer case cause it to reboot
Has anyone had an issue of touching there HD300 with their hand and having the unit reboot.
I think the unit must be grounding out with my touch.
The unit is sitting on a glass tv stand and not touching any other equipment.
Its power is plugged into a monster HTS5100 surge protector -- so the power to the unit should be clean.
If anyone has any ideas or do you think it is a faulty unit
* merged *
Old 02-03-2011, 11:19 AM
ybrew ybrew is offline
do they make a case for the HD300?
Old 02-03-2011, 11:24 AM
davidjames davidjames is offline
* merged *
I have the same situation.
Old 02-03-2011, 01:51 PM
GKusnick's Avatar
GKusnick GKusnick is offline
Get an outlet tester ($5 or so at your local hardware store) and test the outlets your extender and other AV equipment are plugged into to make sure they're wired correctly and properly grounded.
-- Greg
Old 02-03-2011, 02:33 PM
bialio's Avatar
bialio bialio is offline
Same here. Touch it while it's on, get a nice static shock and it turns off. When it turns back on has network issues. Have to remove power completely to restore service.
btl.
PHOENIX 3 is here!
Old 02-03-2011, 02:47 PM
QueOnda's Avatar
QueOnda QueOnda is offline
Isn't it a dc wall plug going into the wall? Doesn't have a ground going into the wall.
Server: HP AMD64 dual core running Win7 64bit (MCE disabled) with 4G memory Tuners: 2 PVR-500(disabled), 3 HDHR and 1 HDPVR Clients: 2 HD200 and 1 HD100 TV: 70" and 52" and 42" Media Storage: ReadyNas 8TB Recording media: 300GB + 200GB+ 250 GB Network: Gigabit backbone'
Thanks to all the developers who work on SageMC, code, utilities and plug-ins to make SageTV better!!!
Old 02-03-2011, 03:15 PM
GKusnick's Avatar
It's AC on the wall plug side, DC on the HD300 side, regardless of whether it has two prongs or three.
You're right that the wall wart does not have a ground prong, but that doesn't mean the outlet can't be wired backwards with the hot and neutral lines swapped. Plus the HD300 connects to other equipment that may have three-prong grounded plugs. It's important that all of it be wired correctly for proper grounding of the whole system.
-- Greg
Old 02-03-2011, 10:41 PM
Now I can not get an ip address from the DHCP Server. I tried all the tricks unpluging it. doing a factory reset. updated to the latest firmware thru usb.
put in a static ip. The router see the device with the static ip but I cannot connect to the Sage tv server.
plus every time I touch it it restarts or the screen goes black for 5 seconds.
The HD300 worked fine for 2 months now it doesnt.
Any one get the device to work with a static ip?
Old 02-03-2011, 10:48 PM
QueOnda's Avatar
Shouldn't matter, if the AC is out of phase because the DC converter just converting to DC to the correct values it needs. This issue is when you have ESD from the finger to the unit. There may be an inadequate design to handle ESD. I'm sure if you you add a GND wire from the chasis to the wall socket or ground yourself before you touch the unit, you would have that problem.
Old 02-03-2011, 10:54 PM
QueOnda's Avatar
I'm able to do the static Ip but I'm using the beta firmware for the HD300. Not sure about latest released version.
Have you tried using a ground strap or touching something else before you touch the HD300? Cold weather really brings out the shocking of other people and door knobs. Is this happening?
Old 02-04-2011, 03:52 PM
splicer splicer is offline
Similar problem here, sometimes my extender won’t come on and I have to walk over to it and touch it there is a small static event (discharge) and then it powers up.
no active red light cansat SageTV Media Extender 4 08-19-2018 06:23 PM
HD-300 Frozen, Blue Purpleish LED light rugerp90 SageTV HD Theater - Media Player 16 12-08-2015 05:23 PM
Net Light Constantly Flickering gabe1475 SageTV Media Extender 3 01-28-2010 03:28 PM
HDPVR - recording, but no blue light loonsailor Hardware Support 0 11-13-2009 02:04 PM
Power light blinking indytbf SageTV Media Extender 4 08-08-2008 09:40 AM
