Old 03-07-2011, 10:35 AM
PLUCKYHD PLUCKYHD is offline
Do not USE Diamond with non beta SAGETV
I just tested this and a whole lot more is messed up than the menu. It appears when we imported into the new STV and started woking with it allot changed. It is a total mess if you are using it with the none beta of sagetv. It is way more than just the tv and exit menu missing.
Old 03-07-2011, 11:58 AM
graywolf's Avatar
graywolf graywolf is offline
If you are running non-Beta Sage, is there a method of installing a Diamond version which was compatible with the non-Beta Sage?
Realize you are not supporting the older Diamond, but is it possible?
Guess I need to read up more on the issues I've briefly heard regarding Sage Beta and HVr-2250 & possibly 1600s
Old 03-07-2011, 02:02 PM
I think Plucky would need to republish 2.0 as new package.
B
Old 03-07-2011, 02:03 PM
tmar89 tmar89 is offline
Confused. Does this mean if I download SageTV 7 from the website and try to use the Diamond plugin, I will have problems?
Still a BTV user considering SageTV... maybe one day
Old 03-07-2011, 02:04 PM
B
It won't let me do that unless I give it a different name as you can't have more than one version in the repository and I am not to keen on having 2.
Old 03-07-2011, 03:43 PM
Biggen Biggen is offline
Plucky,
It might help to write in the release notes in the plugin repository that that Beta 7.1 is needed. I know in the Dependency list that you have listed that SageTV 7.1 is required, but I think a better explanation in the relase notes would help.
Old 03-07-2011, 04:51 PM
Originally Posted by Biggen View Post
Plucky,
People don't read those either. The plugin system is suppose to prevent this from being installed anyways. I hve confirmed with sagetv it is a bug on their end letting it install. They provided a workaround but I havent had a chance to submit a new repository yet.
Success/Bugs with Using Diamond 3.0 with Non-Beta Sage? ptzink Diamond 13 03-06-2011 12:35 PM
Plugin:: Diamond V3.00 for SageTV V7 UI Mod/Themes PLUCKYHD Diamond 5 03-04-2011 10:59 AM
Diamond Sub-theme: Diamond MKANET Mod mkanet SageTV v7 Customizations 2 02-21-2011 05:18 AM
SageTV 3 beta vs. GBPVR beta mkanet General Discussion 3 09-12-2005 10:15 AM
Microsoft Visat Beta 1 & SageTV 3 Beta mightyt General Discussion 13 08-16-2005 08:20 AM
