Diamond This forums is for discussing the user-created Diamond plugin for SageTV. |
Sagetv 7.1.8 Beta and Diamond 3.3
Before anyone asks, Diamond 3.3 has not been tested on tonight's 7.1.8 Beta.
We'll test when we get a chance. It looks like there is no problem downgrading to 7.1.7 as the Wiz.bin is backwards compatible (see release notes) so there shouldn't be any harm in trying it out if your wives will let you ![]() |
Seems to be working so far for me.
Mayamaniac - SageTV 7.1.9 Server. Win7 32bit in VMWare Fusion. HDHR (FiOS Coax). HDHR Prime 3 Tuners (FiOS Cable Card). Gemstone theme. - SageTV HD300 - HDMI 1080p Samsung 75" LED. |
same here. the only thing i noticed is in the detailled recording view - the episode overview and the actors seem to be listed there twice (maybe also in the series overview)
Server: AMD Phenomen IIX4 965 Black Edition, 4 GB, 2x Hauppauge HVR-3000, 2x PCTV DiB BDA - native, Terratec S7, Cine S2 (Dual DVBS2), WinTV-Nova usb via DVBLogic, xmltv, 20TB disk arrays Clients: 3 x MediaMVP, 2 x HD-300, 4 x SageTV Client |
Can you post a screen shot? I can't update quite yet. J |
although i am @work, i try to attach a picture, although it's not easy to show, so i tried to mark the things i saw..
Hoep,
Do you have any other plugins installed other than Diamond? (sorry have to ask ![]() Thanks, J |
Hi jorton,
i do have othe plugins installed: BMT Read/Write/Edit Metadata Commercial Detector Jetty Media Streamin Services Sage MyMovies Webserver/mobile Heap Monitor and of course: Diamond today I noticed that i have the duplicate entries only on shows recorded before the upgrade to sageTV 7.1.8 yesterday but not in shows i recorded since then. So these things might be related to the upgrade process yesterday...
hoep, you should uninstall "Read/Write/Edit Metadata" and install Complementary Metadata Tools (CMT). CMT is the version that you should be using with SageTV 7.1
John |
thx for that info - i did it vice versa - i uninstalled cmt - did not recognize that cmt is replacing read/write/edit metadata.
..correcting now...
Jeremy |
Jeremy,
thank you, your help was very welcome. I will try to confirm my 7.1.7. version anticipation, when i get a chance to do that (tough schedule so far) - and then make a post in the beta forum. hoep
"Read/Write/Edit Metadata" and "Complementary Metadata Tools (CMT)" will both display additional info like what you are seeing if you have a .my file for the recording and "Setup/Detailed Setup/Customize/Metadata Options/.my File Reading/Alwys Read .my Files" enabled.
John |
One thing I did notice is that in the customized recordings Malore menu. If you hit options then the up button you lose the selection bar... even if you hit down it still is not there.
Channels DVR UBUNTU Server 2 Primes 3 Connects TVE SageTV Docker with input from Channels DVR XMLTV and M3U VIA Opendct. |
![]() Thanks, J |
Yeah you are right it happens with the standard... will post in beta forum.
Episode 2x OSD
I notice the episode is listed 2x on the imported tv. Is is possible To have the top episode name to instead reflect the series name. So it would be easier to see what series one is watching.
See Screen attached. Series name is "Star Trek Deep Space nine" Episode is "Meridian" Meridian shows 2x on OSD.
That's another area we don't modify the code. There is so much going on in the upper OSD detail area that we didn't want to mess with it. Edit - How's the metadata looking in BMT? Is all the title/episode info correct? Jeremy Last edited by jorton; 06-12-2011 at 08:09 AM. |
Jorton
Screen cap Attached
Ok, I can see that it's not a recording, so it must be an imported "video" correct?
I have tried to playback a whole bunch of different imported TV files I have to see if I can get the same double episode title but can't make it happen. I am also not seeing the Show title ("Star Wars: The Clone Wars") above the Episode title for an imported TV show during playback... but not doubled like you show. (See Attached) From what I remember of the code depending on the type of file being played back the upper OSD changes to suit. Unfortunately, I am running 7.1.7 still, and can't move to 7.1.8 quite yet ![]() Jeremy |
Yes it is imported TV... I can wait appreciate everything you have done... I think it has more to do with the newest Beta.
BTW I have everything update to the newest.
Migrating from WMC/Diamond to SageTV/Diamond | jrolmstd | Diamond | 5 | 05-03-2011 08:50 PM |
For Team Diamond: Seeking Permission to use Diamond Screenshots | DigiTechRx | Diamond | 0 | 03-11-2011 05:21 PM |
SageTV V7.1.3 Beta & Diamond bugs | nyplayer | Diamond | 4 | 03-09-2011 11:17 PM |
Do not USE Diamond with non beta SAGETV | PLUCKYHD | Diamond | 6 | 03-07-2011 04:51 PM |
Success/Bugs with Using Diamond 3.0 with Non-Beta Sage? | ptzink | Diamond | 13 | 03-06-2011 12:35 PM |
