Phoenix This forum is for discussing the user-created Phoenix custom interface for SageTV. |
Program Guide Question
I have been doing alot of program guide searching and *sometimes* when opening, it is still at the last place i was looking at (which is usually days in the future).
Is there a way to goto the current time/channel? |
If you are using an extender, pressing the guide button again will take you to the current time. I don't know of a way to take you to the current channel.
<EDIT this is true in the default UI, but not in Phoenix>
Server: MSI Z270 SLI Plus ATX Motherboard, Intel i7-7700T CPU, 32GB Memory, Unraid 6.11.5, sagetvopen-sagetv-server-opendct-java11 Docker (version 2.0.7) Tuners: 2 x SiliconDust HDHomeRun Prime Cable TV Tuners, SiliconDust HDHomeRun CONNECT 4K OTA Tuner Clients: Multiple HD300 Extenders, Multiple Fire TV Stick 4K Max w/MiniClient Miscellaneous: Multiple Sony RM-VLZ620 Universal Remote Controls Last edited by bialio; 07-12-2011 at 07:44 AM. |
In the next release there is a menu item in the Options menu that goes to the current time. Until then I think you just have to powercycle the extender to get it to forget where it was. If you are on a full client or server just restarting the client should do the trick.
btl.
PHOENIX 3 is here! Server : Linux V9, Clients : Win10 and Nvidia Shield Android Miniclient |
I have also noticed that fast forward and backwards work in the Guide (going forward or back a screen) but Skip Back and Skip Forward do not go back and forward 24 hours.
Will this be added? Oh and, pressing the record button does not work on the Guide, you have to use select and choose recording options..... Still working great however! ![]()
Server: Tranquil T7 Intel Atom D330, 2GB RAM, Windows Home Server, Sage TV 7.1.9 (Last version ever ![]() Clients: 3 HD300s, 2 HD200s, 1 PS3 |
Yep same request for program guide, also I am overlooking something simple, when iviewing tv how do you easily pull up the info on the program as the info button takes you to a menu with current and recent recordings?
Embarrassingly simple question, How to channel program guide colors on Show type | jptheripper | SageTV Beta Test Software | 5 | 10-30-2010 01:46 PM |
STV Import: Alternative Program Guide & Mini Guide for Default STV | wado1971 | SageTV Customizations | 24 | 09-13-2009 01:32 PM |
How to disable the popup window in the program guide? How to keep the program guide? | metropole | SageTV Software | 8 | 05-18-2006 06:25 PM |
Program guide Question | Gregor | SageTV Software | 11 | 11-30-2004 12:34 PM |
