Old 10-22-2011, 09:03 PM
tombailey tombailey is offline
mass un-archive
after I installed 7.1.9 my existing recordings were all marked as "archived". Is there a way to remove the archive flag from all of them (other than manually)?
Also, all my favorites definitions disappeared. I think I've read that they're listed in wiz.bin so I copied the existing version into the new SageTV directory but the still did not re-appear. Any suggestions?
Thanks.
Old 10-22-2011, 09:26 PM
nyplayer nyplayer is online now
Enable the hidden extras use the malore menus filter archived only... group by single group then you can unarchive all.
Old 10-22-2011, 10:19 PM
fidget's Avatar
fidget fidget is offline
If you have the web interface installed, you can also clear the archived flag enmass.
DVD Storage: 24 TB
Clients: 3
SageTV Extenders:5
Old 10-24-2011, 11:36 AM
thanks to both of you for your replies. nyplayer, I'm not familiar enough with the Malore menus to understand the last part of your instructions. I have Malore with the hidden extras activated and can display archived only but don't know what you mean by "group by group" and I don't see how to un-archive files except by setting individual flags. Thanks again for your help.
Old 10-24-2011, 01:03 PM
When in the Malore view hit options and then you can group by a single group. then you can highlight the single group click ok or select and the you can unarchive.
Old 10-24-2011, 06:50 PM
nyplayer, thanks again for your help. I hope you'll forgive my ignorance but I don't know how to do the last part of your instructions. I can set it to display only one group but I don't know what or how to select to un-archive the group.
Mass Changes to MM Database Possible? itanic Sage My Movies 3 08-26-2011 08:52 AM
mass dvd info import? idvsego SageTV Customizations 1 07-16-2008 10:07 PM
Anyway to mass zap the airing time and duration? tawpgk SageTV Software 12 10-19-2007 02:59 AM
Moving from Archive, but still in archive HeyGuy101 SageTV Software 2 09-09-2007 11:30 AM
Can I use SageTV service in western MASS? Paladin369 SageTV Software 4 06-30-2003 08:18 AM
