Old 05-03-2012, 04:04 PM
craigap craigap is offline
Can't connect to Web UI. HTTP Error 404
I've tried every combination of install/uninstall start/restart that I can and I always get this error. I've tried Chrome, IE8 and IE9. Any help would be greatly appreciated. I've just re installed everything to an SSD. I had all this working fine on the previous install-same computer just a different OS HDD. Could it matter if I haven't installed any Windows updates yet? Could it have something to do with a setting on my router? I've also turned of Windows firewall too to see if that helped and it did not. I also made sure browser caches were cleaned out.
Windows 10
Sagetv 9 64bit (9.2.5)
HVR-2255 x3 OTA
Old 05-03-2012, 06:10 PM
firenice firenice is offline
Port 8080 needs to be opened and may need to be set up in the plugin.
Good Luck
Old 05-04-2012, 11:05 AM
Went to open the port and found that my router's remoted management was throught port 8080, so I change it up and got it working. Thanks.
Windows 10
HVR-2255 x3 OTA
Unable to connect to BMT...HTTP Status 404 thalian Batch Metadata Tools 2 06-05-2011 09:12 PM
Network Error / Unable to connect to sagetv gabrielcab SageTV Software 6 05-03-2011 05:46 PM
Passworded http webcam srcurtis SageTV Studio 1 06-30-2008 08:30 AM
Help - Keep getting error message "failed to connect to IP Address via DHCP" TZen SageTV Media Extender 8 03-06-2008 12:46 AM
http://www.sage.tv NOT WORKING? Sunkman General Discussion 6 09-06-2005 07:50 AM
