I have been meaning to build storage system for some time and space has finally pushed me to make a decision.
I currently own 5 x 2TB WD (EARS) sitting in a nice stack all purchased before the floods at a good price. ![]() I originally bought the 4 of the drives to use with a sansdigital 4 bay esata unit (and included highpoint rocketraid 622 pcie controller) with raid 5 but the drives didn't seem to play well even with wdidle3 applied to them. They would drop from the array (red lights on the enclosure indicator) From what I see my only other option seems to be buy a NAS ($$$) or build some sort of home brew storage with Unraid or similar. For a possible Unraid I have an old AMD x2 5200 on an ASUS M2NPV-VM mATX PC, 2GB DDR2 and 4 onboard Sata2 ports. I have a Silicon Image 2 port sata2 PCIe card to get me up to 6 sata2 ports total. I'm trying to spend the least amount to get the most storage with some redundancy in case I lose a drive and possibly 20% of my recorded / ripped movies. Are there any other options? I have a functioning WHS 2011 box (AMD x4 955 with 8GB ram on ASUS MB) with 6 sata2 ports and an addon highpoint rocketraid 640 (4 ports). Is there something I could use on the WHS2011 box that would give me a large pool like the old drive extender??? This is only for archived tv and movies so I guess speed is only an issue for playback. I won't be recording from Sagetv to these drives. Any thoughts would be appreciated. Thanks. Last edited by jorton; 06-08-2012 at 09:24 AM. |
Drive Bender: http://www.wegotserved.com/2011/10/3...ddin-whs-2011/ DrivePool http://www.wegotserved.com/2011/02/1...e-server-2011/
HD-PVR w/v1.5.6 drivers / Hauppauge IR blaster / FiOS Extreme HD / Motorola QIP6200 / SPDIF+720p Fixed Output on HP Media Center 8400F (Phenom 9500 QuadCore 2.2GHz, nVidia GeForce 8500 GT) via Olevia 247TFHD/Onyko TX-SR606/Harmony 550/HP MediaSmart EX490 WHS w/12TB Plex Media Server v0.9.9.5 on HP Touchsmart Envy 23 d16qd Sonos Play:3, Connect / SimpleTV v2 / Roku 2 XS+Plex / iPhone 5 / iPad 2 |
There's also FlexRAID. While I haven't looked into the WHS add-ins very much (which means they might work similarly), one thing that I always liked about FlexRAID was that it didn't actually mess with your original data. Since it uses a parity solution, it actually cannot corrupt the data you're protecting. Additionally, the drives can be physically removed from the computer and accessed by any other computer.
Server: XP, SuperMicro X9SAE-V, i7 3770T, Thermalright Archon SB-E, 32GB Corsair DDR3, 2 x IBM M1015, Corsair HX1000W PSU, CoolerMaster CM Storm Stryker case Storage: 2 x Addonics 5-in-3 3.5" bays, 1 x Addonics 4-in-1 2.5" bay, 24TB Client: Windows 7 64-bit, Foxconn G9657MA-8EKRS2H, Core2Duo E6600, Zalman CNPS7500, 2GB Corsair, 320GB, HIS ATI 4650, Antec Fusion Tuners: 2 x HD-PVR (HTTP tuning), 2 x HDHR, USB-UIRT Software: SageTV 7 |
Why not use Windows 8 storage spaces? Eventually you'd have to buy it, but for now it's free.
or you could say screw windows and their drive pool and go with unraid... just a thought
I am open to unraid, just trying to avoid having three servers in my basement
![]() It would be nice to use the WHS 2011 box for more than nightly backups. |
Crashplan for unraid works just as well.
SageTV Server: unRAID Docker v9, S2600CPJ, Norco 24 hot swap bay case, 2x Xeon 2670, 64 GB DDR3, 3x Colossus for DirecTV, HDHR for OTA Living room: nVidia Shield TV, Sage Mini Client, 65" Panasonic VT60 Bedroom: Xiomi Mi Box, Sage Mini Client, 42" Panasonic PZ800u Theater: nVidia Shield TV, mini client, Plex for movies, 120" screen. Mitsubishi HC4000. Denon X4300H. 7.4.4 speaker setup. |
Virtualize your WHS2011 and unRAID on the same box if you would rather keep your WHS backups. You could put WHS in a VirtualBox VM on unRAID. Or if your server is powerful enough ESXi with passthrough for unRAID or other NAS OS.
I actually have 3VMs: 1 -unRAID 1 -WHSv1 1 -Win7 SageTV server |
Yes. If you could do ESXi with your server, unRaid would work nicely.
Here is a very good thread with instruction on doing that setup/configuration. It helped me and prior to that, had 0 experience with ESXi or any virtualization. http://lime-technology.com/forum/ind...?topic=14695.0 |
I recommend unRAID for your video library. UnRAID is very reliable and requires no maintenance. You can easily expand the storage by adding more hard drives. WHS is very inefficient compared to unRAID (storage per number of drives). There's no easy recovery with WHS.
Dave |
Thanks guys.
I think I'll try out unraid and see how it goes as test storage then when I get comfortable with it move my library over. Will my old hardware be enough for decent unraid performance? AMD x2 5200 ASUS M2NPV-VM mATX, 4 onboard Sata2 ports, Gigabit Lan (Marvel) 2GB DDR2 Silicon Image 2 port sata2 PCIe card Also, would it be wise to have a single controller with 8 ports for all the drives to run on or is a mix of sata2 controllers (onboard and PCIe) OK? |
That's pretty similar to what I'm running, and it just runs. The only thing I would add is to get one of the paid versions so you can use a cache drive (I haven't done this yet). Writes to the array are very slow without it, since it's always got to write the parity drive.
Sort of an update...
I have ordered an IBM M1015 (LSI9240-8i(???) without the Raid 5/50) with two SAS to 4 SATA cables and have the following possible hardware to use for an ESXi machine, 1) Intel Q6600 Core 2 Quad (VT-x), 8GB DDR2, Asus P5K-E Wifi/AP, with 6 onboard SATA2 ports. No video on board but I have a cheap PCIe video card that will do. or, 2) AMD x4 955 (AMD-V), 8GB DDR2, Asus M3N78-VM with 6 SATA2 ports, onboard video. I think I will need to get an Intel PRO/1000 GT Gigabit Ethernet PCI Network Adapter Card NIC for ESXi to work as I'm not into command line driver installs ![]() My plan (could be crazy...) is to run ESXi 5 with a virtual WHS2011 and virtual unRaid. The IBM/LSI controller would be for unRaid. Any thoughts on what hardware would be better or if I am going it the right direction??? Total rookie on the virutalization thing so any info tips, good install links would be appreciated. Thanks, Jeremy Last edited by jorton; 06-10-2012 at 02:48 PM. |
I'm not sure why you would want to use WHS. WHS is very storage inefficient, only 50%, compared to only 1 parity drive with unRAID. WHS has no recovery path, other than a painful and time consuming scratch rebuild. None of your hundreds of configuration parameters or accessory programs and their configurations are captured.
If you have a hardware or software failure, how do you get the system working very quickly back to a point in time when the system was working perfectly? Maybe there is an answer for that if you can image the host VM. It sounds like there is a lot of complexity going on there. Many things just waiting to fail! I don't know how much processing throughput is left when you virtualize verses using physical hardware for each task. One thing you want to make sure you have covered is how fast can you recover. If your SageTV system is used everyday, by several people, it can quickly become a critical computer system to your family. You want to make sure that it is reliable and when it fails, you want to be able to recover it quickly to minimize downtime. Dave |
I'm new at it also, so can only provide a little info.
Make sure vt-d capable since you'll want to be able to pass through the M1015 (or any other controller card). M1015 Warning! These cards come with an IBM raid bios, you have to re-flash them to LSI IT-mode Bios to work. These do not work with unRAID 4.7. You must run 5.x and newer only Info on Flashing the M1015 here http://lime-technology.com/forum/ind...1131#msg121131 |
@ davephan - I only use WHS2011 for the consolidated backups of my 5 Win7 64 but machines, one of which is my Sagetv server and provides a quick way to restore my wiz.bin through the WHS UI. I don't use the storage options of WHS 2011 as there is no drive extender any more. Way back with WHS v1 I did try the drive extender pool thing but had nothing but issues and never trusted it so I gave up on it very quickly.
If I lose a client machine it's a quick and easy restore using a thumb drive. If the server goes I have the full server backup (new in WHS 2011) and also the clients themselves to rebuild from if needed. @ graywolf - the eBay seller is going to flash to IT mode with the latest firmware and I am looking at ESXi 5 so it should be fine. I'm really trying to consolidate my severs a bit as the WHS2011 box only really does anything after midnight and sits idle the rest of the day so it would be good to serve my media for the rest of the day. |
I have two virtual unRAIDs with Win7 SageTV VMs on a SuperMicro X9SCM-F and a Tyan S5512GM2NR to hold them. I also have a WHSv1 VM on the Tyan board for backups with 4 1TB 2.5 WD notebook drives in a 4in1 cage. That is the only thing I have on it. I found that SageTV was just too sluggish when WHS was doing a backup so I split it into a Win7 SageTV server VM and a WHSv1 VM. |
So long story short the Q6600 would work with VT-d and passthrough if the ASUS P5K-E will. Also based on VMware communities it looks like the P5K-E should work. Actually the HCL lists the P5K-E as compatible so that combo should be fine. Last edited by BobPhoenix; 06-10-2012 at 06:04 PM. |
The linux kernel used in unRaid 4.7 did not have the drivers for the M1015. So you will need to go with unRaid 5.x (most likely the latest Release Candidate would be best). I'm on unRaid 5b11 and you could try 5b12a or the RCs. DO NOT try 5b13 or 5b14 as they had issues with the M1015 |
mass un-archive | tombailey | SageTV Software | 5 | 10-24-2011 06:50 PM |
Mass Changes to MM Database Possible? | itanic | Sage My Movies | 3 | 08-26-2011 08:52 AM |
New to SageTV - Best setup for server and storage questions | gilbreen | Hardware Support | 3 | 09-25-2009 04:10 PM |
mass dvd info import? | idvsego | SageTV Customizations | 1 | 07-16-2008 10:07 PM |
Storage questions, NAS, WOL, lots of stuff! | Kirby | Hardware Support | 36 | 08-21-2006 06:59 PM |
