Old 05-06-2013, 12:23 PM
Skybolt's Avatar
Skybolt Skybolt is offline
USB Capture Device?
Does anyone know if this device will work as a capture device?
http://www.newegg.com/Product/Produc...82E16815116048
I am looking for a low overhead capture device to be used exclusively for PlaceShifter. And it has to be USB.
The HD-PVR creates files to larger to stream, or atleast I think that is my issue there.
Skybolt
Old 05-06-2013, 08:44 PM
Place shifter should work with the HDPVR but it seems to have issues with 1080i files. Try locking your box to 720p.
Old 05-07-2013, 07:27 AM
darcilicious's Avatar
This.
Anything that tries to transcode 1080i on the fly is probably going to have a less-than-perfect experience.
Old 05-07-2013, 12:45 PM
Skybolt's Avatar
Exactly, which is why I am looking for a simpler (SD) capture device.
I am running Sage in a VM, so I can't use a standard capture card.
I tried using SageDTC with the HDHR Prime and that works perfectly, but there are limited channels to watch that way.
Old 05-07-2013, 02:23 PM
You should be able to record from a HVR-950Q as I know that works with SageTV in VM (although I have mine connected to a USB card passed through to the VM for my HD-PVRs and one 950Q). That records from QAM/ATSC/NTSC or uses a software encoder for the composite/svideo input. I've never actually tried it(composite/svideo) because it is a software encoder. It is also nearly twice as much as the one you posted.
Old 05-07-2013, 07:00 PM
Skybolt's Avatar
Originally Posted by BobPhoenix View Post
... or uses a software encoder for the composite/svideo input. I've never actually tried it(composite/svideo) because it is a software encoder. ...
Thanks, but thats why I picked the one I did. I believe it uses a conextent chip for hardware decoding. Not sure though.
Best HD Component Capture Device Tofu Hardware Support 15 07-31-2010 03:43 PM
HVR-1600 Capture Device? m0ng00se30 Hardware Support 10 04-28-2007 10:24 AM
Using Motorola Tuner device for capture device cyberfreak Hardware Support 4 02-22-2007 02:47 PM
No AV Capture Device jaelanicu SageTV Recorder Software 5 08-03-2006 02:02 AM
Video Capture Device - Not Available crashdude Hardware Support 2 03-15-2004 12:14 PM
