capture device recommendation
Hi,
I am needing some advice on what product will work with SageTv. It needs to be USB and at least 1 tuner though more is better. I am running Win7 64-bit SageTv version 7 Over the air (no cable or satellite). No space for internal card - needs to be USB 2.0 or 3.0 I was thinking MediaMVP-HD or WinTV-HVR-1955?? Can you please point me to a Hauppauge device that would work for me? Thanks, Regan |
You mention "at least 1 tuner". I've encountered bandwidth problems when trying to stream from multiple USB devices at the same time. Highly dependent on the USB controller chipset and can be very finicky.
Have you considered a networked tuner such as SiliconDust HdHomeRun? 2 tuners per gadget. I'm currently running a server with 2 HDHRs (4 tuners) for OTA; great results.
System #1: Win7-64, I7-920, 8 GB mem, 4TB HD. Java-64 1.8.0_141. Sage-64 v9.2.1 ATSC: 2x HDHR-US (1st gen white) tuners. HD-200. System #2: Win7-64, I7-920, 8 GB mem, 4TB HD. Java 1.8.0_131. Sage v9.1.6.747. ClearQAM: 2x HDHR3-US tuners. HD-200. System #3: Win7-64, I7-920, 12 GB mem, 4TB HD. Java-64 1.8.0_141. Sage-64 v9.2.1 ATSC: 2x HVR2250; Spectrum Cable via HDPVR & USB-UIRT. 3x HD-200. |
I would second the recommendation for the HDHomeRun tuners. Very reliable and easy to set up.
I've had a number of Hauppauge products over the years and they always seem to be quirky in some way or another. |
USB Capture Device? | Skybolt | Hardware Support | 5 | 05-07-2013 07:00 PM |
TV Tuner Capture Card Remote recommendation | dock | Hardware Support | 7 | 02-12-2010 09:05 AM |
HVR-1600 Capture Device? | m0ng00se30 | Hardware Support | 10 | 04-28-2007 10:24 AM |
Using Motorola Tuner device for capture device | cyberfreak | Hardware Support | 4 | 02-22-2007 02:47 PM |
No AV Capture Device | jaelanicu | SageTV Recorder Software | 5 | 08-03-2006 02:02 AM |
