Old 08-01-2016, 06:52 AM
Android MiniClient 1.0.5 - Released
Change Log
- Animation updates (less flicker)
- Fixed crash on Android N
- Updated libaries (ExoPlayer, IJKPlayer, and LibGDX) to latest versions
So the biggest things here is that I found a bug in the UI rendering that was causing the animations to be less smooth and would sometimes flicker, so hopefully that is fixed.
The libraries for ExoPlayer and IJKPlayer (and LibGDX -- UI library) has been updated to their latest versions... i think that is ExoPlayer 1.5.9, IJK 0.6, and libGDX 1.9.3).
This is published to the Play Store and Bintray.
Old 08-01-2016, 10:47 AM
DarkWolf77 DarkWolf77 is offline
Got the update. Couple of odd things with it, though. I had animations disabled since they were so weird with previous versions. Turns out that with this update it causes the menu's to not clear the screen if video is playing (I thought video was totally not working, but when I backed out to the main Sage menu video was indeed playing). When I turned animations back on it mostly works but there is definitely some weirdness there with artifacts being left behind on the screen but when the animation "finishes" it clears out ok - mostly an improvement over the previous behavior for sure, though.
Old 08-01-2016, 10:51 AM
With this update I get bits of the menu and sometimes all of the menu covering the Video it appears it is not clearing the navigation screens. Screen Attached sound is playing but no Video.
Using ShieldTV.
PS I uninstalled 1.05 went back to 1.04 and everything works.
PSS I had to turn off auto update.
Old 08-01-2016, 12:29 PM
Sadly I didn't do any testing with Animations disabled It appears the things are not getting cleared when animations are disabled, which is too bad I'll look into that.
Using ShieldTV.
Do you have animations disabled?
Old 08-01-2016, 12:32 PM
Yes I always disable animation ... even on my PC Clients.
Old 08-01-2016, 02:35 PM
I created a 1.0.6 with a configuration option "Animations Disabled?" in the Setting screen. If you disable animations in SageTV, then enable this option, and it should fix the rendering issues. This is a temp solution until I can find more time to research what is happening.
Old 08-01-2016, 03:24 PM
That worked.
Thank You
Old 08-01-2016, 09:04 PM
bialio's Avatar
bialio bialio is offline
With animations turned on this update is WAY better for me.
PHOENIX 3 is here!
Old 08-04-2016, 08:28 AM
Lester Jacobs Lester Jacobs is offline
Change Log
Just wanted to chime in and say a big Thank You for all your effort on this. Never thought I'd see SageTV running this well on a tablet. This will be a big hit with the rest of the family.
Lester
Lester Jacobs
Web: http://www.digicasa.com
"The shortest answer is doing."
English Proverb. Collected in: George Herbert, Jacula Prudentum (1651).
Old 09-03-2016, 11:10 PM
troycheek's Avatar
troycheek troycheek is offline
Just picked up an Nvidia Shield Tablet K1 to replace my dead Kindle Fire HD. (Said Kindle started working again as soon as I placed the order, of course.) The Android MiniClient was the first thing I installed. Still trying to figure out the interface (Nvidia game controller helps!), but no major problems so far.
Old 11-16-2016, 01:27 PM
Carey Carey is offline
Exoplayer mode with No Audio
I just discovered your SageTV mini client Android app v.1.0.11. I am running it on a Android TV STB called the Tanix TX5, running Android 6. The server is SageTV v9.
The app works quite well, but when I enable Exoplayer mode in the app settings, playback has no audio. And occasionally the screen is black if I start playback mid way into the video.
I was wondering if this a known issue with the app when using Exoplayer mode? Or is it just a general issue with Exoplayer on some Android devices?
I'm curious if you had any insight into why this might be. I'm also curious what advantages Exoplayer mode has over the "normal" mode of the app. The UI seems smoother and slightly faster, unless it's my imagination.
Thanks for your reply, and for sharing this app with us!
Old 11-16-2016, 01:32 PM
ExoPlayer is an experimental player. It only supports hardware decoding, whereas IJKPlayer (the default) supports pretty much anything (will use hardware decoding if available, but will use software if not). I don't consider ExoPlayer to be ready in terms of general playback, but maybe some day, it'll be there.
Android MiniClient - Subtitle + CC support stuckless SageTV Clients Development 42 01-01-2018 08:17 AM
Android MiniClient for TV is Released to the Play Store stuckless SageTV Clients Development 106 01-08-2017 01:42 AM
[Android MiniClient] Now in BETA stuckless SageTV Clients Development 487 07-03-2016 03:55 PM
[Android MiniClient] Need a better start screen stuckless SageTV Clients Development 16 01-29-2016 01:55 PM
MPEG2 Support in Android MiniClient stuckless SageTV Clients Development 24 01-03-2016 10:09 AM
