OpenDCT vs SageDCT for upgrade to v9 from v7
I'm going to upgrade my v7 server to v9 soon using a clean install, using v7 wiz.bin and clean installs of all plugins.
I have two Ceton InfiniTV 4 PCIe cards doing my recording now in v7 using SageDCT. I was wondering if there is any reason to use OpenDCT over SageDCT in my situation mentioned above? It seems like OpenDCT may be simpler to setup than SageDCT, so that would be a plus. Just not sure what to do at the moment. Also, should I use the latest stable release or the latest beta release, that is if I use OpenDCT? Any help is appreciated. Thanks, Chuck
OS: Windows 10 Pro (64 bit) Motherboard/CPU/RAM: Gigabyte EP43-UD3/Intel Core 2 Quad Q9550 @ 2.83 GHz/8 GB RAM System Drive : Samsung 850 Pro SSD (256 GB) Recording Drive's: 2 x WD WD4001FAEX (4 TB) Tuner's: 2 x Ceton InfiniTV 4's Clients: 3 x Nvidia Shield TV's; Spares: 2 x HD300's SageTV v9.1.2.662 with OpenDCT v0.5.28 Java 1.8.0_111-b14 (32bit) |
I would definitely suggest moving to OpenDCT, if for nothing else, than it's maintained.
Additionally, it can send the stream directly to SageTV (MediaServer mode) instead of writing to the file directly - this bypasses permission and sharing complications AND allows the stream to pass through sage's native remuxer, which will clean up the stream, thereby fixing the occasional (or frequent, depending on your provider) timeline issues that can come up with digital cable broadcasts.
That is that I was thinking as well. Do you have any opinions on if I should stick with the stable version or go with the beta version? Not sure if there are any benefits for my Ceton tuners or not to go with the beta version. Thanks for the help, Chuck
Definitely Beta.. really it should be considered stable at this point, and has left the 'stable' version pretty far behind.
Thanks again Fuzzy for the feedback. I'm probably doing to use OpenDCT with a clean install of v9. Once I have that version seeing my tuners, then I will drop in my v7 wiz.bin file and hope all is well after it upgraded the database.
+1. I've been using it for a while and it's very stable.
Basically the idea is that the stable version has less features, but is better tested and only gets updates for horrible problems weighed against the potential for even worse problems. The beta will generally be fairly far ahead of stable because of this, but can potentially have more surprises for new features or big fixes. I am always running the latest beta and often am running what will be the next beta in my production server.
SageTV v9 Server: ASRock Z97 Extreme4, Intel i7-4790K @ 4.4Ghz, 32GB RAM, 6x 3TB 7200rpm HD, 2x 5TB 7200rpm HD, 2x 6TB 7200rpm HD, 4x 256GB SSD, 4x 500GB SSD, unRAID Pro 6.7.2 (Dual Parity + SSD Cache). Capture: 1x Ceton InfiniTV 4 (ClearQAM), 2x Ceton InfiniTV 6, 1x BM1000-HDMI, 1x BM3500-HDMI. Clients: 1x HD300 (Living Room), 1x HD200 (Master Bedroom). Software: OpenDCT :: WMC Live TV Tuner :: Schedules Direct EPG |
Are there any features that I would be missing for the Ceton InfiniTV cards specifically? I don't really know what this program does above just allowing SageTV to see the cards and record. I guess I just really need the basic functionality but don't want to upgrade too often. Thanks, Chuck
Thanks again, Chuck
HDHomeRun Prime + OpenDCT...so close! | c4674593 | SageTV v9 Customizations | 10 | 11-09-2021 07:37 PM |
Sage 9 on Ubuntu 16.04 w/OpenDCT | chairmanmao | SageTV Github Development | 24 | 11-21-2016 09:35 PM |
Broke my OpenDCT? | ThePaladinTech | Hardware Support | 2 | 03-29-2016 03:19 PM |
OpenDCT: Can I use it? | SDeGonge | Hardware Support | 7 | 02-20-2016 10:27 AM |
InfiniTV4 with OpenDCT | tomdomm | Hardware Support | 58 | 02-03-2016 07:00 PM |
