Old 04-28-2007, 03:16 PM
Where to buy IR emitters in Canada?
Hi Everyone,
Does anyone know where to buy IR emitters in Canada that are compatible with the USB-UIRT?
Something along the lines of http://cache.smarthome.com/images/8171.jpg
-Peter
Old 05-01-2007, 11:36 AM
wvpolekat wvpolekat is offline
Send a message via AIM to wvpolekat Send a message via MSN to wvpolekat
Why not build one? It's simple.
http://65.36.202.170/phpBB2/viewtopi...4e5695727cbb4f
Old 05-01-2007, 02:34 PM
Berg Berg is offline
I built my own 2 zones emitters based on the instructions on the USB-UIRT forum. It is really easy !
Old 05-01-2007, 04:28 PM
jdamore jdamore is offline
Great Project... easy!
Heres another site:
http://www.modders-inc.com/how-to-story--16.html
Old 05-01-2007, 06:50 PM
Thanks for the responses.
Would these parts work for making an emitter?
http://www.thesourcecc.com/estore/Pr...roduct=2740244
http://www.thesourcecc.com/estore/Pr...roduct=2760142
I would still prefer to buy a premade solution, since I don't have a solder iron and don't have much experience in this type of thing.
Thanks.
-Peter
Old 05-01-2007, 07:29 PM
Thanks.
-Peter
When I made mine, I used parts I got from The SourceCC. However, what you need is an IR emitter (the ones you found are emitter/receiver I believe) and I am quite sure a 1/8" stereo plug. Just take the USB-UIRT with you to make sure you have the right jack and pick an emitter.
I looked at premade emitters in Canada but never found any for a reasonable amount. You could buy some on eBay and have them shipped, but at the end of the day, it all adds up for a pretty simple project. MHO.
Old 05-01-2007, 08:18 PM
I don't see The SourceCC selling the emitter's separately. It looks like you can only get it in a pack with the receiver too... unless I'm missing something?
-Peter
Old 05-01-2007, 09:32 PM
I just made up a pair of them here on the couch.
Pair of IR emitters from Radio Shack, old cat 5 patch cable for wire, pair of mono 1/8 plugs from RS and a stereo to mono splitter from RS.
I realized after I got home I didn't have any solder, so for now it's a twist job until I make it back to Radio Shack (30 min from here), unless Wal-Mart has solder.
First, I cut the modular connectors off the end of the cat 5 and stripped the sheath off, leaving me with 4 twisted pairs to use for the emitters.
Connected one end of a pair to the 1/8 mono plug, then the other end to the 2 legs of the LED.
The splitter comes in because the plug on the usb-uirt is a stereo plug, think one channel for each emitter. But, since RS didnt have a 1/8 stereo plug, I got a stereo to mono splitter to let me use the mono plugs.
Should have a chance to test it tomorrow, but it's pretty simple wiring and I can't imagine it wont work.
Total cost was $12 US, which is cheaper than I can get even a single emitter shipped to me. A little heat shrink and some solder and I will have a nice pair of emitters.
But, now that I have 3 total emitters and only 2 tuners, it looks like I will have to add a 3rd tuner to fully utilize my capacity Somehow I don't think my wife will agree with my logic.
Old 05-02-2007, 06:42 PM
Just got mine actually installed and setup today.
I wonder if there is a market in making these.....
What do I need to buy? greg.d SageTV Linux 5 03-31-2008 11:06 AM
Best place to buy an IR Blaster in Canada? aclarke SageTV Canada 2 07-17-2006 01:45 PM
Which Hauppauge 150 to buy? roge Hardware Support 3 05-07-2006 06:53 PM
Looking to Buy Sage Bundle mike1961 Hardware Support 4 12-13-2005 10:05 PM
Looking for a SageTV bundle in Canada... ddesmedt SageTV Canada 5 11-02-2005 08:11 PM
