Old 08-11-2017, 05:40 AM
STV fixes for SageTV7.xml
While working on a few STV tweaks, I figured I would also look into fixing (or removing) some broken things in the STV.
The main one that comes to mind is the issue to remove broken items from the Online menu. Personally, I think this means pretty much everything except for "Weather", but I suppose I'll just remove "YouTube Videos" and "Channels.com". That would also include the YouTube/Google video search options elsewhere.
I also saw a comment somewhere about DScaler options not being useful... ?
Are there other things to be fixed or removed?
Thanks.
Andy
PS: Note that I'm not looking for suggestions for new features to add; just trying to fix a few things.
Old 08-11-2017, 10:25 AM
Here's what has been updated so far, though not submitted yet:
  • Removed random misc adjectives after some show titles on malore menus
  • Fixed Music by Artist filtering when entering characters
  • Removed Zap2it logo from System Info screen
  • When configuring an EPG lineup: changed the instruction text, moved SD option to top position, renamed old SageTV EPG option to be for XMLTV/plugins.
  • Disabled access to YouTube, Google videos, and Channels.com... and related options, search menus, etc.
  • Reworded Sync System Time option
  • Removed debug logging option, since that is always enabled now.
Andy
Old 08-11-2017, 10:38 AM
SHS's Avatar
SHS SHS is offline
Yes please do clear all the on Online stuff as there only few channel that are still even open
As for DScaler it should be remove it keep mind that it was only useful with SageTV v7 codec filters.
Something else that need be to fix is change Video/Audio Renderer so that all of them set as default if I recall it was MPEG-2 codec that are show as SageTV codec.
Old 08-11-2017, 10:42 AM
wnjj wnjj is offline
Maybe change the wording on the 'sync EPG clock with Sage server' to a more generic 'EPG server'.
Old 08-11-2017, 11:00 AM
I just changed the online things I listed above. I don't plan to review all the entries in the online videos properties file. Maybe someone who uses those feeds could take on the job of updating that list.
Since I'm no filter expert... If that's the case, isn't it possible long term SageTV users still have & use those filters? Is DScaler useful to anyone at all?
I don't know what you mean here -- all the options have a "Default" choice the user can make. ??
Andy
Old 08-11-2017, 11:04 AM
pjpjpjpj pjpjpjpj is offline
Thanks, opus! (and my wife thanks you in advance for the music search fix).
How/when will this be issued? I haven't done any upgrades or updates since switching to v9 so I'm not familiar with how it's being done. Will a notice pop up in the notifications area or will I need to watch here and go download a new install?
Old 08-11-2017, 11:08 AM
In case you missed my post on this the other day, you can work around it for now by entering an extra char, then removing it (backspace or Stop command).
I'm sure it will just be in the next version release.
If you watch the updates on github (or this topic, I suppose), you could just download the STV.
Andy
Old 08-11-2017, 11:13 AM
Tiki's Avatar
Tiki Tiki is offline
Andy
I think that on new V9 installs, it is defaulting to the SageDecoder, even though that decoder isn't installed, so new users get a playback error. They then need to go to the Settings menu and change to "Default" (which uses whatever the system default is on their computer), or select a specific decoder.
He is suggesting that we should make "Default" the default value.
,USBUIRT (multi-zone)
Source:
Comcast/Xfinity X1 Cable
HDHR, HVR-2250, HD-PVR
Old 08-11-2017, 11:25 AM
The STV doesn't set the default initially, but I did find a video playback test screen in the config wizard that I'll check out.
Andy
Old 08-11-2017, 11:30 AM
graywolf's Avatar
graywolf graywolf is offline
I assume this will be for the default STV only and no change/impact to the V3 Full UI?
Old 08-11-2017, 11:41 AM
Another change:
  • Config Wizard playback testing menu uses "Default" instead of "SageTV MPEG <xx> Decoder" settings.
Correct. I don't use and have no plans to update an older UI that is out of date in many more ways than what I've mentioned here.
These changes are for SageTV7.xml; thread title updated.
Andy
Old 08-11-2017, 01:24 PM
SHS's Avatar
SHS SHS is offline
Yes that right Tiki
Old 08-11-2017, 04:24 PM
graywolf's Avatar
Andy
Completely understand and wasn't expecting changes to the older UI.
Just wanted to validate my assumption
Old 08-14-2017, 12:04 PM
The STV changes are now in github & will be in the next release, or you can download from github if you want to try it out sooner.
If you do download the STV, get the online video properties files too, since they have some of the YouTube, Google Video, and Channels.com online video sources removed.
But, the changes aren't critical, so waiting for the next release is fine.
Andy
Old 08-14-2017, 12:31 PM
Isn't YouTube still being maintained by tmiranda, or is that happening via a Plugin rather than the core UI?
Old 08-14-2017, 01:33 PM
My understanding is that the built-in YouTube stuff is not used. I'm sure tmiranda will let me know if that is incorrect and I removed something needed.
Andy
Old 08-14-2017, 04:16 PM
Tiki's Avatar
Andy
So does that mean the updated STV only be distributed as part of a full Sage install (or by grabbing files off of Github)?
I had assumed we would receive a system message about an update (I'm not sure exactly what mechanism was used to push the STV updates, but thought it was similar to or part of the Plugin system).
Source:
Old 08-14-2017, 04:28 PM
At this time, yes, STV updates will come with installer updates. This, frankly, is much easier to manage than the old style update files and server. We discussed making the STV updates a part of the Plugin system, but none of that work has been done currently.
Old 08-15-2017, 05:22 AM
tmiranda's Avatar
tmiranda tmiranda is offline
Andy
I'll make sure YouTube continues to work.
SageTV9 Server / SageTV7 Network Encoder or SageTV7 Windows Client sflamm SageTV Github Development 10 02-19-2017 06:56 PM
BMT 4.9 / Phoenix 2.3 - Bug Fixes stuckless Batch Metadata Tools 1 10-31-2010 06:22 PM
Consolidation of HD-PVR changes/fixes fitzpatr Hardware Support 1 03-22-2009 06:15 PM
Juke Box Fixes extreme.paradox SageTV Beta Test Software 1 01-17-2005 08:43 AM
SP2 has fixes for VM9 in it. edgley General Discussion 1 01-05-2005 10:43 PM
