Old 05-13-2021, 02:04 PM
jvl711's Avatar
jvl711 jvl711 is offline
TheMovieDB java library
Hi All,
Wanted to let you guys know in case there were any developers looking to do some metadata work, that I posted a library that I use in my own STV for managing metadata. If anyone is interested in using it I can give them a quick overview. It has not SageTV specific parts, but I did write if for SageTV use.
Contributions are welcome.
Link: https://github.com/jvl711/TheMovieDB
Josh
Projects I am currently maintaining
SageTV Andoid Client
Media Format Parser Plugin
JavaFFmpegLibrary
SageTVTranscoder
If you like the work I am doing and would like to support it you can become a Patreon member.
Old 05-14-2021, 01:00 PM
cncb cncb is offline
I am interested if you think it will download most of the actor thumbnails that seem to be missing for my movies using Gemstone. Does it just replace BMT or does it run externally to SageTV? Thanks.
-Craig
Old 05-16-2021, 06:25 AM
jvl711's Avatar
This is going to be a little disappointing, but this is just a library that one could use to write something like BMT... I do however have my own replacement to BMT, but it is for my own STV. I am slowly working on releasing it. There is a lot of code libraries that I need to release first.
Josh
JavaFFmpegLibrary
SageTVTranscoder
SageTV 6 Client problems after Java 7 install, Java 6 uninstall alisonnic SageTV Software 5 01-24-2013 02:51 PM
Java SE7 Favorite limit day problem (vs Java SE6) voidpt SageTV Software 0 10-21-2012 12:29 PM
Demand for Custom Picture Library and Music Library screens? PLUCKYHD SageMC Custom Interface 62 09-13-2009 06:52 AM
Tables, Java - Java Not being Called for each TableComponent Cell stuckless SageTV Studio 3 04-02-2008 03:03 PM
Beta V1.2.2 Java java.lang Null Pointer Exception hamptonhills SageTV Beta Test Software 1 03-27-2003 12:11 PM
