Old 05-20-2008, 12:46 PM
Arrow STV Update Tests for beta v6.4
Since the beta is the best time to try out these new features so they can be fixed if there is a problem, I have prepared a new STV file set update test. Please try updating the STV while using v6.4.3 & later, then let me know if there are any problems.
For testing purposes, I suggest that you follow these steps:
  1. Make a backup copy of your existing <SageTV install path>\SageTV\STVs\SageTV3\SageTV3.xml file. This is the file that will be updated for these tests and you don't want to lose that file in case there is an error. The update process has worked for me every time I tested it, but make a backup just in case.
  2. Go to Setup -> Detailed Setup -> Advanced, then choose the Check for STV Update option. If you've imported customizations into your default STV, it will check for an available update but will not install it until you return to the unmodified default STV to see if there really is an update available.
  3. After the update, check System Information to make sure that the STV version has changed to the version from the update.
  4. If there is another update available, there should be a dialog saying so & that you should check again after the new STV has loaded.
Thanks for testing!
Old 05-20-2008, 12:55 PM
matt91's Avatar
matt91 matt91 is offline
Andy,
Am I reading that the new STV update will be installed without affecting any currently installed customizations? (Or at least that's what is supposed to be happening?)
Matt
If you've imported customizations into your default STV, go ahead & try this while using the customized STV & see what happens.
Old 05-20-2008, 01:00 PM
No... sorry, I guess I really ought to have specified that instead of leaving it vague for people to find out when they test it.
The STV update process requires that you have the default STV loaded (SageTV3.xml). It will check for an update if you are using a customized STV that has chaged the filename & should let you know if an update is available, but it tells you to load the default STV & check again. (The default STV may have already been updated.)
After updating, you will need to re-apply any customization imports.
Old 05-20-2008, 01:09 PM
MeInMaui's Avatar
MeInMaui MeInMaui is offline
It would be pretty cool if it could:
  1. Automatically do a diff against the existing SageTV3.xml
  2. Generate an STVi
  3. Apply the update
  4. Automatically import the STVi generated in step 2.
If there are any errors detected (i.e. the new STV is incompatible with some of the customizations) then it could default back to the new SageTV3.xom file with a notification that the customizations were not automatically imported. Just a thought.
Aloha,
Mike
- Nikolaus (4yrs old)
Old 05-20-2008, 01:11 PM
doc's Avatar
doc doc is offline
Andy
I use the standard stv by default, and it worked exactly as you described.
I see it also makes a backup of the current stv before updating it.
Dave
Old 05-20-2008, 05:37 PM
Mike: I don't know if we'll ever extend it like that, but I think that might generate too many emails to support. I considered having some sort of system to re-apply the imports, but an STV update could break a customization. I think people should look into the batch updater in the customizations forum. We'll see where this basic updater eventually leads, though.
Great!
Yes -- any existing files that the update contains will get backed up, adding the old version number as the new extension for the file. And, if the update fails at some point, all those renamed files should get put back to their original filenames.
Old 05-21-2008, 01:56 AM
JREkiwi's Avatar
JREkiwi JREkiwi is offline
Andy, worked well. Nicely prompted to switch STV's on my customized STV.
Maybe an option from that prompt could be to switch to the default STV and update.
John
Old 05-21-2008, 03:49 AM
zzmystique's Avatar
zzmystique zzmystique is offline
Andy
If you have SageMC loaded there is no update option at all under advanced.
Once I switched back to the default stv it updated without a hitch.
Anne
ZZMystique
My setup: Server: SageTV v7, Intel i5, 8GB, 180GB SSD, 4TB HDD, Win7HP & (DVB Viewer Pro with DVB Viewer for SageTV using 2xTBS6281 DVB-T2).
Old 05-21-2008, 08:50 AM
I've been considering an option to switch to the default STV... it would definitely have to check again after it is loaded, though, because it could be possible that the default STV is already up to date while the custom version was based on an older one.
Well, yes, this is only built into the default STV. However, I'm working on a way to let custom STVs like SageMC use the most recent default STV for setup rather than the modified default STV it currently uses.
BTW: the unzip code now built into the default STV could be used by customizations for purposes other than updating the default STV.
Old 05-21-2008, 10:13 AM
geogecko geogecko is offline
I can see it now, pop-up, "A new version of SageMC is available, would you like to update." Of course, I choose, "yes," and Sage responds by saying, "Thank you." Sage then says, "I see you have MovieTimes and SMG installed, would you like those reimported when the STV is updated?" Well sure, go ahead Sage, that would be awesome of you...
-Jason
Old 05-22-2008, 11:42 PM
There is a new STV file set update available, which installs version 2008052301.
See the first post of this topic for instructions.
The update dialog lists all the changes.
See Using the default STV in Custom STV Mode from custom STVs for details on one of the new features that custom STV develoeprs can use.
Old 05-26-2008, 08:48 AM
doc's Avatar
doc doc is offline
Andy
The updates work on my XP server but my Vista client gives an error when it tries to rename the existing stv.
Before you say it, yes I know I should know better
Old 05-26-2008, 08:55 AM
What part should you know better about?
Has anyone else tried this on Vista? I don't have Vista, so maybe there is something I need to work around, such as the VirtualStore.
Old 05-26-2008, 09:07 AM
doc's Avatar
doc doc is offline
I should know better than running Vista, it wouldn't let me edit a vbscript earlier either.
The stv file is in the program files area and not the virtual store. If I try to rename it manually I get the message
'Destination Folder Access Denied. You need to confirm this operation'.
I have UAC turned on.
Old 05-26-2008, 09:31 AM
Motofreak75 Motofreak75 is offline
Send a message via ICQ to Motofreak75
Andy
try to install Sagetv client in "c:\sagetv client" and not in program files folder, and you shouldn't have an issue. Even with UAC off, there is still a security policy that makes Admin user accounts act as regular users in the Program files folder. and other certain system type folders on that O.S. that will prevent overwrite/renaming and deleting of files.
try it out and see if it works. I have to do install some programs to the the root to make things work.
12.04 server Sagetv7
HD-pvr / 2250 /PVR 500 / DVBS w/rotor & 36 inch dish
Old 05-26-2008, 10:20 AM
doc's Avatar
doc doc is offline
Yup, that worked a treat, cheers
Old 05-27-2008, 10:20 PM
Test update for Vista
Thanks for reporting the issue using this update system on Windows Vista.
I've got an update to try which I'm hoping will fix the problem. Would someone using Vista with UAC turned on and whose updated properties files are being saved to the VirtualStore please test this update, following these steps:
  1. If you do not have debug logging enabled, please do so.
  2. Download the attached zipped SageTV3.xml, make a backup copy of your existing SageTV3.xml, then replace the original with the new version. Make sure this file gets placed in the SageTV install directory, rather than the VirtualStore. (If this isn't possible for some reason, the next update tests replacing other files too.)
  3. Load the new SageTV3.xml file as your STV in the SageTV UI -- this must be done even if you are already using that STV. Make sure that System Info says the STV file set is 2008052800.
  4. Go to Detailed Setup -> Advanced -> Check for STV Update. It should find an update for file set 2008052801. Install the update. If it succeeds, then System Info should now list 2008052801 as the STV file set.
Let me know whether this update works for Vista. If it fails, I would like to see the log, or at least the portion of the log after it says "Checking remote online video version file".
Thanks.
Old 05-29-2008, 02:45 PM
So... have either of the 2 people who downloaded the Vista test version above tried updating while UAC was on?
There is another version available: file set 2008052901. See the update dialog for details, but it contains some fixes for online videos, among other things.
If you are using Vista, you should really download the attachment in my previous post before trying to install this update.
As usual, let me know if there are any problems with the updates. Thanks.
Old 05-29-2008, 03:10 PM
doc's Avatar
doc doc is offline
Andy
I'll download it tomorrow when I get home and can play with my Vista pc again.
My first priority though will be plugging in my new STX-HD100
Working away all week is a PITA!
Old 05-30-2008, 01:22 AM
jakep_82 jakep_82 is offline
Worked for me. Previously it wouldn't update with UAC on, but after replacing the STV file it worked great. Now running 2008052901
Just a few basic question to get me on track perry59 SageTV Studio 2 11-02-2007 12:41 PM
STV Initializations vs. ApplicationStarted hook Opus4 SageTV Studio 4 07-07-2007 10:06 AM
STV: Display Show logos (May 29, 2005 update) laurenglenn SageTV Customizations 151 10-25-2005 03:18 PM
STV: malore's STV for SageTV (Oct 15 update) malore SageTV Customizations 205 11-23-2004 01:59 PM
