Old 09-03-2018, 06:02 PM
xjim1's Avatar
xjim1 xjim1 is offline
Favorite Option to Limit to 1/2 Hour?
A lot of shows i watch these days are old reruns, which on several channels are run back to back. They're also 30 minutes episodes. Is there any way I can create a favorite to record a single 30 minute episode within the hour?
Ex:
MASH is a 30 minute show on at 7pm and 7:30pm same channel every weekday.
I only want to create a favorite for the 7pm episode.
Is there a way to use a keyword or a category to do this? I really don't want to make timed recordings if I don't have to.
Thanks for any help.
Old 09-04-2018, 06:54 AM
will will is offline
Originally Posted by xjim1 View Post
Ex:
Well there is no built-in way to do exactly what you want, however there may be some workarounds based on your watching habits.
If you watch MASH every night but only the first 30 minute episode then create a favorite that is set to record MASH between the hours of 7pm and 8pm, set auto delete to no, and keep at most to 1; SageTV will only record the 7pm episode. However, SageTV will not record any other episodes of MASH until you delete the current 1 recording.
May I ask though, why do you care if your system records two episodes of MASH vs just one?
Will
OS: Windows 7
Old 09-04-2018, 05:06 PM
xjim1's Avatar
I guess a better question to ask is; I only want to watch episodes from a particular season, especially, catching the beginning of season 1 of a series. I tried using keywords, like specifying "season 1", but that doesn't work. I admit I don't really know how keywords work in that sense. Is there a way to do that?
This question ties into my original one as often times multiple seasons will be shown in a single day. The MASH example was a little over-simplified. Still nice to have the "Hour" parameter in 30 minute increments, though.
Old 09-05-2018, 09:33 AM
This solution may depend on your guide history but you could:
  • Set all episodes and watched in the advance section of the favorite
  • In the favorite go to view additional recordings > click on past airings > manually mark all Season 1 as unwatched
I think your cleanest, quickest, and easiest solution would be to set the recording to a limited time, 7pm to 8 pm, and once a week clean out the wrong recordings by marking them as watched or don't like so STV won't record them again.
I've been using SageTV for 9 years and I have never once needed that feature or read about anyone wanting that feature; I think your situation could be an edge case...
Will
OS: Windows 7
Old 09-05-2018, 09:07 PM
xjim1's Avatar
First of all, thanks for helping out . It's nice folks are still participating in the forum.
I have resigned to performing manual intervention in these situations.
Ironically, I played around more with keywords in creating a Favorite and discovered pretty much every field is searchable EXCEPT air date (which includes episode information). With reference to the manual (p.71), this seems to be a bug.
I have no doubt my usage behavior is not common. Probably explains my lack of popularity with usability/UI teams throughout my career.
I argued here for variable playback speed functionality years ago, which showed no interest either, yet it was a primary feature in DVR's at the time.
Cheers
Old 09-06-2018, 05:54 AM
I just thought of one other option, it is outside of SageTV though. I could help you write a batch script that will delete all episodes of MASH that don't contain S01 (Season 1) in the file name. By default SageTV should save the Mash recordings as "MASH-S01E01-PILOT-75465445.mpg".
It would be relatively easy to write a script that would delete all MASH-* from your recording directory unless it contains S01. You could then schedule this script to run nightly. I believe the old recordings though would still show up in SageTV until the service is rebooted or an advanced rescan was performed.
Otherwise, I can't think of any other work arounds with the current version.
Is variable playback speed when you watch a 30 minute show in 25.5 minutes because the system plays back the frames/audio 15% faster than normal?
Will
OS: Windows 7
Old 09-06-2018, 05:47 PM
xjim1's Avatar
That's not a bad idea, actually, and currently within my skill set. I say that as I can just go to a recording directory and easily delete all unneeded files, since they'd be listed sequentially. But I'll take a raincheck on any help offered if I ever want to automate it.
Do they actually do that?
No, when I say variable playback, I mean slow-mo/single-step. Handy for screen captures and even better for analyzing plays in sports. I'm a little surprised that didn't garner more interest.
Lastly, if you or anyone can try creating a favorite using the season and/or episode keywords as part of the air date information, I'd like to verify this indeed does not work as documented.
It has to be in quotes, such as "season 1" or "episode 1".
Cheers
Old 09-06-2018, 06:44 PM
jusjoken jusjoken is offline
While paused if you press and hold pause then it does step forward...kinda slomo.
k
Old 09-07-2018, 02:48 PM
I thought of one other hack solution the other day but it depends on the number of tuners you have.
Create favorites for shows that air every night at 7:30 pm, like Wheel of Fortune, and set their priority higher than Mash, set the new the favorites to auto delete and to keep at most 1. Mash will record at 7pm but not 7:30 pm because your tuners are busy recording other shows.
Will
OS: Windows 7
Old 09-08-2018, 10:22 PM
xjim1's Avatar
k
I tried that with my HopHog remote but it didn't work. Thanks for the suggestion.
I created the config as you suggested. Will let you know the results.
Cheers
Plugin to limit guide to only favorite channels? skyeclad SageTV v7 Customizations 7 12-09-2013 07:36 AM
STV7 suggestion to allow multiple selections for Limit to Day/Hour GoAWest SageTV Software 1 03-06-2011 04:39 PM
3 Hour Limit on Recordings???? james_k_p SageTV Software 39 10-03-2008 11:03 AM
Any way to limit number of favorite recordings? JasonJoel SageTV Software 9 03-27-2003 05:39 PM
