Old 11-14-2006, 10:23 PM
CarolinaGuy CarolinaGuy is offline
Service Provider Not Listed
My service provider is not listed in the SageTV set-up menu. Most of Davidson County, NC uses Time Warner Cable - Davidson County.
I have downloaded trail version just to check an see if my cable provider is listed.
This page shows the line-up.
http://www.timewarnercable.com/Custo...nu=Programming
Can TIME WARNER CABLE - DAVIDSON COUNTY be added? Can I do it locally? Is there a work-a-round?
I have posted a note to support.
CarolinaGuy
Old 11-14-2006, 10:29 PM
If you've put in your zip code & your provider isn't there, then the 2nd Q of this FAQ tells who to contact... but since you've contacted support, they'll probably be able to look into it. Make sure you've given them your zip code.
Old 11-15-2006, 09:05 PM
Pretzelboy Pretzelboy is offline
Are you absolutely sure about this? I don't have SageTV set up yet but the information that Sage and Zap2It both use come from the same source and Zap2It has your line up just fine. I matched it against the Time Warner website line-up listed for Time Warner Cable - Davidson County.
Zap2It has line-ups listed for:
Time Warner Cable - Cable ( Lexington )
Time Warner Cable - Digital ( Lexington )
I used 27292 for the zip code.
