Old 02-03-2008, 10:48 PM
Skiier__Dude's Avatar
Skiier__Dude Skiier__Dude is offline
HD100 Bricked after latest firmware?
Hey all,
I had been having some video stuttering issues and intermittent lock up problems with my HD100, so on Friday I updated it to the latest firmware. Unfortunately now, after the unit discovers my server the screen goes blank. I have followed the procedure to force a manual update to the firmware, and after it restarts, same issue -- screen just goes blank. I tried going back to the older firmware version without success this waY (http://forums.sagetv.com/forums/showthread.php?t=30323) I have also tried the latest beta version of the firmware to see if that solved my problem but still no joy.
Server is running 6.3.7 -- the server and another client work as good (or better) than they ever have with the new code. HD Extender is hooped.
Any suggestions?
Old 02-03-2008, 11:09 PM
Motofreak75 Motofreak75 is offline
Send a message via ICQ to Motofreak75
with the screen is blank. powered on, have you tried to hit the aspect ratio button see if the video comes on ?
12.04 server Sagetv7
HD-pvr / 2250 /PVR 500 / DVBS w/rotor & 36 inch dish
Old 02-03-2008, 11:22 PM
Yes, even went in and reconfigured the Video Output a couple of different ways, but that didn't work either.
Old 02-03-2008, 11:54 PM
carlgar carlgar is offline
I had that issue the other day, first time in quite a while since I had seen it. Try shutting down sage and rebooting your computer. I believe it is caused because the HDx is unable to obtain a license. When I see this happen I have issues with other Sage software, such as PS and the client.
Old 02-04-2008, 10:22 AM
Fixed!!!
Thanks Carlgar -- the fix was as simple as restarting the server. Things appear to be happy once again in TV-land.
Old 02-05-2008, 09:45 AM
sacrament055 sacrament055 is offline
I believe I saw a trend with regards to the problem you experienced. In my case I noticed the event log on my server showed an error approximately every 2 days that coincided with the HD extender and MVP failing to communicate. My client (on the server) continued to work after this though. The solution in my case was to create a bat file to stop and restart the service every night (Early morning) so that it never reaches the point of the error every two days. So far so good.
Old 02-05-2008, 10:37 AM
srothwell's Avatar
srothwell srothwell is offline
Originally Posted by Skiier__Dude View Post
Hey all,
Any suggestions?
It may not be bricked. I have been having issues where the main Sage server goes stupid and forgets it's an extender/placeshifter server. The symptom is exactly as you describe.
I've had to reboot the server since 6.3.7 three times to get placeshifter & extenders to work again.
Stacy
Old 02-05-2008, 11:46 AM
Narflex's Avatar
Narflex Narflex is offline
Sage
If anyone has log files from their server when this occurred please file a bug report so we can get them from you.
Jeffrey Kardatzke
Google
Founder of SageTV
ISO Support in Latest Firmware?? Spanqboy SageTV Media Extender 35 11-12-2008 04:28 PM
HD100 problems Kirby SageTV Media Extender 14 02-26-2008 06:17 PM
Cn't update HD firmware, anyone do this with Vista? carlgar SageTV Media Extender 12 12-21-2007 07:45 AM
Soapbox: Against using the term 'latest version' RobJ General Discussion 0 08-04-2007 11:28 AM
MVP Firmware Versions mdnttoker SageTV Media Extender 10 10-23-2006 05:31 PM
