Old 06-26-2011, 04:58 PM
crusing crusing is offline
Advanced Options in Cover Flow View
Am I missing something or is there no way to bring up the advanced file options while in Cover Flow? I.E. Metadata search etc.
Old 06-29-2011, 07:44 AM
71_Cuda 71_Cuda is offline
+1
Old 06-29-2011, 08:41 AM
bialio's Avatar
bialio bialio is offline
It defaults to the simple options in the current release. The next release will let you choose between Simple and Detailed.
PHOENIX 3 is here!
Old 07-01-2011, 10:31 PM
eopian's Avatar
eopian eopian is offline
I'm sorry if this is a basic question, but how do I use the cover flow for movies? I see all of the other options except for coverflow (single list, banner flow and grid flow).
Thank you!
Server: i3-7100, 16GB Ram, AVerTVHD Duet(OTA), HDHR Prime, 2x2TB(recordings), 128GB m.2 SSD(os), 500GB SSD(data), 1x2TB (Movies), Win10Pro 64bit
Client 1: STP-HD300, Onkyo Tx-Sr707
Client 2-4: STX-HD100
Network: Linksys Router/Wifi, Netgear GS116 Switch, Cat5e/6, Intel NICs
Old 07-02-2011, 10:21 AM
eopian's Avatar
Nevermind, I found it. It's not in the UI, you have to manually edit the menus.
Old 07-02-2011, 07:08 PM
AWS's Avatar
AWS AWS is offline
... can you share what menu you edited to get cover flow (fan art) for All Movies?
THX!
386DX, 40MB HDD, 5-1/4" & 3-1/2" Floppies, 14.4K baud modem, DOS 6.2 and Windows 3.1 on a Samsung 55" LCD
Old 07-02-2011, 08:18 PM
PiX64's Avatar
PiX64 PiX64 is offline
From the landing zone hit options, then go to landing zone options. Then go to customize landing zone highlight videos hit right arrow twice. You will see a ton of views both hidden and show. All movies cover flow is a default I think hidden by default
Old 07-02-2011, 08:21 PM
AWS's Avatar
AWS AWS is offline
Thank you very much!
Old 07-02-2011, 08:37 PM
PiX64's Avatar
No problem!
All Phoenix settings, views, etc can be modified from bmt also. U don't even need to be in the tv ui! All ya gotta do is
Login to bmt web ui and go to configurations. There is a phoenix section there and u will see all options which are available through out different screens in the ui.
Old 07-02-2011, 10:41 PM
AWS's Avatar
AWS AWS is offline
Ok, first, thanks for giving the info about BMT/Phoenix config. Great to know.
How do I make my cover art show up in grid view of All Movies? In the mean time I'll keep searching the forums for this.
Thx.
AWS
Old 07-03-2011, 06:55 AM
PiX64's Avatar
There should also be a default view in te same location I mentioned above for wall view.
*it's called all movies movie wall.
Old 07-03-2011, 07:24 PM
AWS's Avatar
AWS AWS is offline
Yeah, I found that. As soon as I group by title (example, six rips of Star Wars and maybe a dozen Max & Ruby) I loose all the cover art. Is there a menu item for that?
Old 07-03-2011, 09:48 PM
PiX64's Avatar
No I don't think there is. Would need a custom vfs and menu fragment I think. Not 100%. Sure how to do it though without laying with it. Wrems and I were discussing on another thread "vfs examples". Head over there and check out the examples we put. If I get some time tomorrow I'll see if I can get it to work. Bialio or stuckless may be able to just answer that off the top of their heads for ya...
Old 07-03-2011, 10:15 PM
bialio's Avatar
The wall view allows you to group if you wish to, however it will only show posters for individual items. It's really intended for flat views.
btl.
PHOENIX 3 is here!
Problem w Folder View and Music Cover Art kkelley929 SageTV Beta Test Software 2 09-28-2010 04:39 PM
SageMC + Advanced Video Options moothekow SageMC Custom Interface 1 09-20-2009 02:45 AM
Extender Hangs then crashes on Advanced Options computer33 SageTV Media Extender 0 06-04-2008 06:13 PM
Chnange default advanced recording options lcddream SageTV Software 1 12-28-2006 08:21 PM
Help/question: Favorite advanced options scorpion SageTV Software 5 01-12-2006 02:12 PM
