Old 06-29-2011, 07:19 PM
dblaine2 dblaine2 is offline
HD300 no longer playing HDPVR recorded content
I have a strange problem that has resurfaced..
Months ago my HD300 stopped playing content recorded from my HDPVR (I just get a black screen and no audio). I logged a ticket with SageTV and they told me to uninstall and reinstall the latest SageTV and run a force reindex. This fixed the problem for a few weeks.
The problem has returned. I tried the quirky fix above to no avail. I can play the content on the server just fine.
I am run SageTV 7.1.9 and the latest beta firmware on the HD300.
Any ideas?
Dave
Old 07-01-2011, 06:49 PM
Pulling my hair out on this one (and there isn't much to start with).
The offending videos like this newer episode of Burn Notice show format of:
MPEG2-PS[MPEG2-Video/3.8Mbps 4:3 480i@29.97fps, MP2/384Kbps@48kHz Stereo]
Yet here is another Burn Notice from last year:
MPEG2-TS[H.264 4:3 480i@29.27fps, Dolby Digital/384Kbps@48kHz Stereo]
Total Media still shows TS format...
Dave
Old 07-02-2011, 06:27 AM
profit profit is offline
try going back to an older hdpvr driver
At your own risk:
When arcsoft updated I experienced the same issue. I had to go back to original CD from Hauppauge after wiping out all arcsoft drivers including registry entries. I'm still having some stability issues with the HDPVR but I think that device is just dying (3+ years old). I now have to reboot it every second day.
Old 07-02-2011, 07:12 AM
eopian's Avatar
eopian eopian is offline
I have found only the 1.0.5.3 drivers to be stable with my HDPVRs. There is a modified version floating around AVSForum that will let you use it with some of the newer revision hdpvr's.
Server: i3-7100, 16GB Ram, AVerTVHD Duet(OTA), HDHR Prime, 2x2TB(recordings), 128GB m.2 SSD(os), 500GB SSD(data), 1x2TB (Movies), Win10Pro 64bit
Client 1: STP-HD300, Onkyo Tx-Sr707
Client 2-4: STX-HD100
Network: Linksys Router/Wifi, Netgear GS116 Switch, Cat5e/6, Intel NICs
Old 07-04-2011, 09:50 AM
I uninstalled and installed the version on the HDPVR disk. It didn't fix the problem.
Dave
Old 07-17-2011, 07:15 AM
I also have a HVR-1600 and that stuff plays back fine. The only thing I noticed is that the audio in the stuff that works says Dolby Digital... whereas the stuff that doesn't says MP2... I am going to try converting some videos to see if that helps.
Dave
Old 07-17-2011, 07:38 AM
I went searching and didn't find any... Can you point me to where you found them?
Dave
Old 07-17-2011, 07:26 PM
Dave
Hurray, the conversions play!!!
Old 10-14-2011, 06:20 PM
Figured it out...
I found that my permissions were wrong... About the time this stopped working I moved my Windows workgroup network to an AD domain. I converted the Sage service to use an AD service account instead of the local administrator. I added this AD service account to the administrator group in AD thinking that would get applied to the Sagetv machine. Wrong!
I should have added the service account to the local administrator group directly on the Sagetv machine or add him to the the Domain Admins group in AD which is a member of the local administrator group on the Sagetv box. I chose to add him to Domain Admins. Once I did that, the funky MP2 audio encoding went away and now reads H.264 as expected.
Windows permissions.... Sheesh!
Guess that's why I'm a UNIX guy!
Dave
HDPVR - One show's recording has another encoder's content scottwed SageTV Software 0 03-02-2011 10:07 PM
HD300 no longer seeing server Robert Wise Hardware Support 5 02-17-2011 09:47 PM
Playback Schedule Live & Recorded content macro2020@gmail SageTV Software 6 02-23-2010 02:57 PM
HD200 stopped playing HD content brewston SageTV HD Theater - Media Player 1 03-08-2009 09:36 PM
stretch mode not working for HDPVR content pat_smith1969 SageTV Beta Test Software 9 07-11-2008 06:45 PM
