Old 09-13-2008, 12:26 AM
mariOwing mariOwing is offline
How to combine channels on two lineups?
I have two lineups but many of the channels are the same. I would like the identical channels to show only once in the guide, how do I achieve this?
I have read the forums and the manuals and tried different things but I haven't been able to figure it out and make it work. Please help
Old 09-13-2008, 12:55 AM
Channels with the same names should get combined in the guide -- in the PDF manual, see the note at the bottom of the chapter 3 section for the Program Guide.
I think you are outside the US & are not using the built-in EPG data, so if you have channels with the same names that aren't combined into a single listing in the guide, then it may have something to do with how the channels were added to SageTV.
Old 09-15-2008, 01:53 AM
Thank you for your answer, that's what I was hoping for!
I has been using XMLTV Importer for SageTV (http://www.lmgestion.net/@en-us/4/22/54/59/article.asp) and with that program created two lineups and imported those in SageTV. The Call Sign is the same for the same channels on the two lineups, but my guess is that SageTV has added some kind of identifier to them as well so the guide doesn't see them as the same channel. Is there any files/registry settings I can edit/look into in hope of achieving my ultimate goal; combined listing?
Old 09-17-2008, 03:52 PM
In case anyone happens to do a search or something I got the solution from Stéphane Menguy, the author of the XMLTV plugin. If you have two lineups in the XMLTV importer, you must not only give them the same call sign but also the same ID. I changed and matched my lineups and now everyting works the perfect way (one channel shown once in the guide). Thanks!
Poor video quality on some channels JmpnJimBob Hardware Support 6 12-24-2007 12:13 PM
Combine OTA and cable channels in guide? popechild SageTV EPG Service 6 08-21-2007 06:12 PM
Handling cable lineups with both digital and analog content dalleyg SageTV EPG Service 8 08-07-2007 12:27 AM
Jacksonville Comcast Lineup - Lost HD Channels MTuckman SageTV EPG Service 1 04-10-2007 09:51 AM
TVTV and two different lineups... What can I do? potpiejimmy SageTV EPG Service 2 01-27-2006 03:48 PM
