Go Back   SageTV Community > SageTV Products > SageTV Mac Edition
SageTV Mac Edition Discussion related to the SageTV Media Center for Mac edition. Questions, issues, problems, suggestions, etc. relating to the SageTV Mac edition should be posted here.
Old 09-11-2010, 09:08 PM
datoney datoney is offline
Unable to perform any updates
Hi all, so I go into detailed setup, advanced and click on update and I get this error message.
"Unable to download the STV file set update version information"
I am currently stuck at version 2009092201, this is a brand new install of SageTV. The reason that I am trying to perform the update is because my HD200 is spontaneously rebooting every-time I hit the watch live TV button, I have had no problems until today and have not changed anything so I have no idea why it just started rebooting. Any help would be much appreciated.
Datoney
Old 12-10-2010, 03:14 AM
reema12 reema12 is offline
I would also like to know why any updates are not possible on this. I do not have any idea why this error message flashes every time we go for an update. I had also tried this and got struck at the same problem. And I think that once you update it your rebooting problem will automatically stop. Now, on the update error I will let you know if I get any breakthrough. I am working on it.
pop up tv lift
Old 12-10-2010, 08:29 AM
kbates kbates is offline
You have to to it manually
I had this same problem and contacted Sage support. Their answer was to do it manually. Instructions are in http://forums.sagetv.com/forums/showthread.php?t=43453. After following the instructions (downloading the zip file and installing), it worked fine.
FYI, I had the same problem with HDHomeRun not updating, and the solution was similar: download the files manually and install that way.
- Ken
How well does it perform? Elijah SageTV Placeshifter 0 01-13-2007 12:11 PM
Hookup to current running sage, and perform actions? alon24 SageTV Studio 2 06-28-2006 06:21 AM
So what updates do I need? ry12a General Discussion 7 01-22-2004 08:51 AM
