Old 10-15-2011, 08:46 AM
Slugger Slugger is offline
Plugin: mc2xml EPG Plugin
After months of development time spent here and there, I'm pleased to announce the first public beta of my mc2xml EPG Plugin.
Originally, this plugin was to use Schedules Direct as its source, but licensing issues have prevented that to date. There is an SD version of this plugin sitting on my private svn repository, but it's unclear at this point whether or not it will see the light of day. In the meantime, this plugin grabs its EPG data from mc2xml.
Because of how EPG plugins must be hooked into the Sage core, there are special instructions required to completely install this plugin. Please read the installation section of the user guide carefully before starting an installation! It's not overly complicated or difficult, but does require some extra care. Same for an uninstall - you must do some manual steps to uninstall this plugin. All the details are outlined in the user guide.
Please read through the user guide carefully before installing this plugin. There are a few known issues with switching away from the Sage EPG service to this one along with some features of the Sage EPG service that this plugin cannot provide. All the details are outlined in the user guide. Pay special attention to the "Known Issues" section for a key issue that can cause recording of previously recorded episodes.
I'm quite pleased with the results and have actually moved my production server to this plugin for EPG data - mainly for the show and airing filter capabilities. I realize the Sage EPG service is around for at least another nine months (and maybe longer), but I'm hoping to get a few people to at least try it out and provide some early feedback - better to tweak and fix bugs now than hit them after the Sage EPG service is gone.
If you find this EPG plugin useful, I encourage you to donate to the mc2xml author. Without mc2xml, this plugin would not be possible.
Twitter: @ddb_db
Capture: 2 x Colossus
STB Controller: 1 x USB-UIRT
Old 10-15-2011, 09:46 AM
Jabroni's Avatar
Jabroni Jabroni is offline
Nice Job! More EPG Alternatives
SageTV 7.1.9 / Phoenix
Captures: 1x Genpix Skywalker DVB4Sage / 1x 7500 Prof DVBS2 Tunner DVB4Sage / 1x HD HomeRun / 1x Slingbox M1 / 1x Colossus HD
Extender: 2x HD200 / 1x HD300
Old 10-15-2011, 09:51 AM
rlvogel322's Avatar
rlvogel322 rlvogel322 is offline
Wow, great work and thank you Slugger!
Server - unRAID 6.1.3: VM-Windows7 with Sage 7.1.9 - 2xHDHomeRun 1xHDHomeRun Prime - Xeon E3-1230, SUPERMICRO MBD-X9SCM-F MB, RAM 16 GB, HD 14TB
Clients: 2xHD100, 1xHD200 and 1xHD300
Old 10-15-2011, 12:07 PM
Slugger,
Working great thanks.
Old 10-15-2011, 05:54 PM
HelenWeathers's Avatar
Slugger: Job well done, Man!!
Works like a charm. Thanks!!!!
Old 10-15-2011, 10:47 PM
tvmaster2's Avatar
tvmaster2 tvmaster2 is online now
Kingston, on?
this is welcome news!
When you mention: "You just can't assign different, unique lineups to different tuners with the unlicensed version of the plugin...."
that would apply if you were subscribing to both a sat and cable co. and their independent lineups?
ps. have you seen a band in Kingston, 'The Tonecats,?
Old 10-15-2011, 11:56 PM
Correct. You can only download full, predetermined provider lineups via mc2xml - you can't pick and choose individual channels like you can with the Sage EPG service. If you needed to download a cable and a sat lineup and wanted both lineups to be visible to Sage then you'd have to do one of the following:
1) Run the licensed version of the plugin. This will make all lineups you configure visible to Sage via the plugin.
2) Generate the xmltv.xml file with mc2xml (or maybe even xmltv*) on your own, outside of this plugin/SageTV. Point this plugin to some phony exe that simply eats the command line and returns success, then this plugin will proceed with processing the xmltv.xml file you generated externally.
3) Build your own version of this plugin and remove the licensing requirements. You're responsible for rebuilding and redeploying with each code update, but you can build it with all the licensed features without needing a license. Be aware, however, that code changes are going to be occurring often over the next few months. The EPG data processing will probably need some tweaks and there are advanced features still to be implemented.
#1 is the easiest, I think #2 is probably the next easiest then #3, though I'm kind of on the fence as to which is easier between #2 and #3. Your abilities with compiling Groovy code to Java byte code might influence your personal ranking of these tasks.
* Using anything other than mc2xml with the "microsoft legacy" service to generate the xmltv.xml file will probably result in failed EPG updates. If users want to produce xmltv output from other sources to be processed by this plugin then I'm willing to accommodate, within reason. I do plan on adding support for at least the other sources supported by mc2xml, but I may also be willing to support other xmltv generators. However, as of right now, only the input from the mc2xml "microsoft legacy" settings are supported - anything else will probably fail.
They don't ring a bell. The only band from Kingston that I listen to with any fanfare is The Tragically Hip. If you're from Canada, you know who they are. If you're not, then you probably don't.
Twitter: @ddb_db
Old 10-16-2011, 12:18 AM
tvmaster2's Avatar
Choice number one is fine with me.... $7 to $20, correct?
The Tonecats are a rockabilly band that a high school friend fronts. They have a Facebook page - you can see them at local pubs.
Old 10-16-2011, 05:55 AM
tmiranda's Avatar
tmiranda tmiranda is offline
And I thought the only band to come from Kingston was Bob Marley and the Whalers
Old 10-16-2011, 06:57 AM
The Tragically Hip are awesome. Love their bass riffs...
Server: MSI Z270 SLI Plus ATX Motherboard, Intel i3-7100T CPU, 16GB Memory, unRAID 6.3.2, SageTV & OpenDCT Dockers
Old 10-16-2011, 09:35 AM
tvmaster2's Avatar
didn't you know? Bob was a hoser
Old 10-16-2011, 12:13 PM
Slugger,
The full Digital lineup can be huge I have over 500 channels and only use a few. I was able to limit them by creating a file mc2xml.chl and putting it in my line up folder.
mc2xml.chl
2-71
99
106
119
121
128
129
136
164
181
183
233
200-399
500
502
504
515
702-715
Old 10-16-2011, 12:32 PM
Slugger,
Yes, I need to add this to the docs. The plugin will honour and use any of the additional config files that mc2xml will accept as documented on the mc2xml site.
However... by doing this, any new channels added to the lineup will not show up in Sage unless you remember to add those new channels to this config file in your lineup folder.
By downloading all channels and disabling the ones you don't need in Sage, new channels in your lineup will be added as they're added to your lineup in mc2xml.
Twitter: @ddb_db
Old 10-16-2011, 12:59 PM
Good point... I will try out the full lineup.
Old 10-16-2011, 01:40 PM
rnadeau's Avatar
rnadeau rnadeau is offline
Multiple lineups
Just to make sure I understand correctly. I have to create a folder under sagetv\plugins\mc2xmlepg for each lineup. IE. c:\program files\sagetv\sagetv\plugins\mc2xmlepg\timewarnercable for the analog lineup and c:\program files\sagetv\sagetv\plugins\mc2xmlepg\timewarnercabledigital for the digital tuner lineup and run mc2xml from the command line from each folder?
Sage Tv Server-Amd 4200FX quad core, Asus Nvidia EN610 Hdmi out , 8 Gig Ram ,(3) HVR-1800, 3.5 terrabyte storage, Windows 8 Pro on sage 9.09 system . Media Server- 6 Terabytes on 5 drives, Amd x2 6000 8 useable gig ram on win 7 32 bit media server.
Old 10-16-2011, 02:45 PM
Correct, assuming each of those are distinct/unique lineups in mc2xml.
Twitter: @ddb_db
Old 10-16-2011, 03:09 PM
rnadeau's Avatar
Thanks. I just installed it with 2 different program lineups and it works great. Only problems is each channel is listed twice in the lineup in the channel. Not 2 separate listings. It used to be the network icon, then channel number and then the listings by time. Now it is 2 2 then the listings by time. IE. 2 2, 3 3, 4 4 and so on.
Old 10-16-2011, 03:37 PM
Not quite understanding this one. Screenshot?
Twitter: @ddb_db
Old 10-16-2011, 05:48 PM
rnadeau's Avatar
Here is the screenshot.
I think I know what is happening. I noticed that on the channels that have a high definition equivalent, It shows its equivalent and on all others is is the same number. For instance for for the disney channel it has 68 985 as you will see in screenshot2. In the first screenshot, channel 6 has an hd equivalent which is 706 but it doesn't show it it just shows 6 6 wcsh in screenshot 1.
Old 10-16-2011, 06:23 PM
A couple of things...
1) You're not going to get channel logos anymore using this plugin. You'd have to install one of the channel logo plugins to get logos back.
2) Do you get the same behaviour using the stock Sage STV or from the web plugin when viewing the EPG?
Twitter: @ddb_db
Plugin: MizookLCD (Alternate SageTV LCDSmartie Plugin) cslatt SageTV Customizations 48 06-11-2012 10:44 AM
SageTV Plugin Developers: Any way to see stats for your plugin? mkanet SageTV Software 4 12-12-2010 10:33 PM
Plugin Manager: Configure plugin medwynd SageTV Beta Test Software 0 05-29-2010 08:43 AM
Hulu: Possible to Use XBMC Hulu Plugin to create SageTV Plugin? Brent SageTV Customizations 8 02-24-2009 04:16 PM
