Old 11-15-2012, 06:16 AM
pjpjpjpj pjpjpjpj is offline
IMDB gone?
I noticed yesterday that the IMDB search has disappeared, both from the info popup menu and also from the "More online services" menu. I am fairly sure that the recent update to Phoenix was the only thing I've changed. Is it possible that it accidentally killed the IMDB link? Anyone else noticed this?
Server: AMD Athlon II x4 635 2.9GHz, 8 Gb RAM, Win 8.1 x64, Java 8, Gigabit network
Software: SageTV v9, stock STV with ADM.
Old 11-15-2012, 08:14 AM
Nothing in the latest phoenix release would have affected IMDB, and phoenix doesn't actually contribute any UI elements (unless you are running Phoenix UI).
Old 11-15-2012, 08:14 PM
Well, looks like I'm back to the big mystery that no one can answer. I don't use Phoenix (UI) or BMT or Gemstone or Diamond. I have CMT installed, which was what was providing me with the IMDB search. I have the basic Phoenix for v7 plugin installed (not the UI stuff). However, something I have, as I have posted here before, gives me automatic metadata fetching.... even though I don't want it. And no one can tell me how to turn it off, because everyone seems to swear that I shouldn't be getting it.
I've been told numerous times that what I am seeing could not happen without BMT. But I swear, I'm not crazy, BMT is NOT installed (I've checked and checked again) and I am still getting automatic metadata. No, really, I am. Whenever I add a new video, if the name can be found, it gets metadata, thumbnails, the whole nine yards. This even happens if I happen to name one of our home videos something remotely close to a movie name that's in the database. It's annoying - and if I were adding videos as frequently as others here, it would be downright infuriating.
So I suspect that whatever happened has something to do with crossed wires between Phoenix and CMT. The only reason I say this is that CMT provides the IMDB search and the Phoenix Core Services update is what apparently made the IMDB search disappear.
Anyone?
Old 11-15-2012, 10:23 PM
JREkiwi's Avatar
JREkiwi JREkiwi is offline
Is the CMT plugin showing as enabled? As stuckless said, Phoenix api does nothing with the UI, but it is a prereq for the CMT plugin.
As for the automatic metadata etc. check your sage.properties for
phoenix/fanart/automatedFanartEnabled=true
and change to false
John
Old 11-15-2012, 10:37 PM
Anyone?
I'm not sure who told you you shouldn't have metadata being fetched. The Phoenix API does that automatically, by default. You should be able to disable the autofetching from the Plugins -> General -> Phoenix API -> Configure Plugin screen.
Old 11-16-2012, 06:28 AM
Anyone?
You certainly don't need BMT installed to "automatically" have fanart fetched. As Fuzzy pointed out, this is a handled by the Phoenix Core plugin. Phoenix is broken down into 2 NON UI part, the phoenix-api and the phoenix-core. If phoenix-core is installed, then it will enable automatic metadata/fanart lookups by default. No BMT required. BMT is only used if you want to manually lookup metadata and fanart for specific shows, or do a "Batch" update of many shows/moviies.
While I don't use BMT very often, I do use it in cases where the automatic updater in phoenix fails for some reason. I can use BMT to manually update the file. BMT still uses Phoenix to do all the updating, but it just allows more manual control of the process.
Many plugins depend on Phoenix API or Phoenix Core for many fanart/metadata related operations.
The last couple of releases of Phoenix were related to the Weather APIs that Gemstone is using.
But I would check the installed plugins and see if any are showing up as "disabled". It may be that during the last phoenix update, when sage updated it, it didn't extract it properly, and as a result it isn't installed correctly, which would account for why things are not working.
Old 11-17-2012, 02:09 PM
You got it, stuckless. CMT was enabled, but I disabled it and re-enabled it, and IMDB came back. Must have been something that didn't quite load right when I updated the Phoenix stuff last time. Thanks!
Old 12-01-2012, 06:35 PM
It has stopped working on my setup also. I have 2 SageTV HD100 extenders and it doesn't work on either of them suddenly.
I'm using the default STV.
Phoenix Core Scvs and Phoenix API 2.3.56 were last updated and that is about the time it stopped working. I was out of town when those updates went live on 11/18 and installed them sometime between Thanksgiving and a few days ago.
When I do an IMDB search either searching for a person from the program info, or going to search IMDB I get:
"Found 0 results for xPerson (or xTitle, etc), (person, title, etc string), in the IMDB". There is a "Search Again" button above that error message
On occasion I've also seen an error message with the URL that it is using for the search listed. When I get this, there is no "Search Again" button, just the Error with the URL and I have to use the back command to get out of that screen.
Again, I'm 99.9% sure this all started when I updated the Phoenix Core and API to 2.3.56. It is the only update/addition I applied near that time.
No other plugins or updates have been applied anywhere near the window when it stopped working other than those 2. And any that were updated/installed didn't knock out the IMDB search. IMDB stuff was working for weeks after any of those updates/installs.
Update: I just saw a message over on the Complimentary MetaData Tools thread saying that IMDB made a change and that an update is needed to CMT's scraping of IMDB results.
Wayne Dunham
Old 12-01-2012, 07:51 PM
appelm appelm is offline
Same problem here
Old 12-07-2012, 01:48 PM
kemputer26 kemputer26 is offline
UPDATE: I went trolling through my installed plugins looking for stuff I could remove for potential conflict, and found nielm_sageimdb installed and indicating "Update Available"
Updated that plugin, IMDB searches are working fine now. Cheers.
Same problem. Seems to have stopped working when Phoenix update was installed a few days ago. IMDB searches no longer functioning...anybody have any ideas how to get IMDB working again?
Old 12-07-2012, 02:00 PM
Skirge01's Avatar
Skirge01 Skirge01 is offline
Make sure everything is up to date (STV's & plugins). My IMDB searches are still working just fine.
Software: SageTV 7
Old 07-03-2013, 05:12 PM
dvd_maniac's Avatar
dvd_maniac dvd_maniac is offline
every GVid trailer Search returns the message:
"No videos were found"
I used to love this feature so I can watch a trailer right from Sage before deciding on what to watch...
I just did a fresh install of Win7 and SageTV and only installed BMT and CMT so I don't think it's a messed up plugin issue.
Anyone else having this issue?
If this doesn't work right, Then:
"I'm going to blow up the Earth!"
Old 10-13-2013, 07:04 PM
Skirge01's Avatar
I just started having issues with IMDB lookups from the SageTV UI tonight. Anyone else? Error message attached. Sadly, I don't actually know which plugin provides this capability.
Software: SageTV 7
Old 10-13-2013, 07:10 PM
It works fine make sure you have the CMT plugin installed... If you do have it uninstall it and reinstall it.... maybe something got corrupted.
Old 02-21-2014, 12:49 AM
Skirge01's Avatar
Having issues once again. This started after the forums came back online and after the latest webui update, but I'm not sure what precisely caused it. It could be a change on the IMDB website itself. It's specific to looking up actor names, though.
Anyone else able to confirm?
Software: SageTV 7
Old 02-21-2014, 12:52 AM
Mythikal's Avatar
Mythikal Mythikal is offline
I'm seeing the same thing.
Old 02-21-2014, 01:13 PM
Not at home to check mine but I have noticed that in the past few weeks, the actor bios have disappeared. Everything else seemed to be working fine. Maybe if it's dead now, we can get the whole thing fixed up?
Old 02-22-2014, 12:35 AM
JREkiwi's Avatar
It's a change on the IMDB web site that has broken it. I've had a quick look at it and it appears as though it might take some time to work through all the changes.
John
Old 02-22-2014, 05:19 AM
John
Same here, everything seems to work except when you try to get a persons info. Show/movie searches work, and you can list the actors, but if you try to click on one you get the error.
I was hoping it was already fixed. I looked at my plugins and there were two Phoenix files that needed updating and Json. No change, same symptoms.
Thanks for the quick confirmation and I'll await the update.
Wayne Dunham
Old 02-22-2014, 11:18 AM
Skirge01's Avatar
John
Damn you, IMDB!!! Thanks for looking at it, JREkiwi. We will now patiently await your expertise.
Software: SageTV 7
IMDB does not work JohnLG SageMC Custom Interface 4 01-12-2010 03:40 AM
imdb Hans SageTV Customizations 0 07-10-2009 11:41 AM
IMDB vs DVD Profiler shinnlly SageMC Custom Interface 2 03-30-2009 05:33 AM
IMDB Ratings scandx SageTV Customizations 4 09-16-2007 03:41 AM
IMDB look up issues. sevenlas SageTV Customizations 2 08-03-2007 11:54 PM
