Old 07-31-2014, 10:40 AM
mkanet's Avatar
mkanet mkanet is offline
Spinning circle when playing back TV Recordings
For the last few days, I'm seeing a spinning circle when I start to playback TV Recordings or tune into a TV channel.
One important thing to note... when I see the spinning circle, I also see an instance of SageTVTranscoder.exe sometimes actively consuming CPU.
I'm not sure why this would happen since this happens even when playing back files locally (SageTV client on the SageTV Server PC).
Does anyone know what's wrong? I already replaced the TV Recordings hard drive. I also replaced my Wiz.bin with a new one. I have more than enough RAM and unused Java heap memory.
So, what could trigger this kind of behavior? When the SageTV client has a spinning circle, the onl;y way to stop it is top restart my SageTV server.
Edit: It looks like the problem went away on its own...
***RIP SageTV***
Old 08-01-2014, 05:43 AM
ranger ranger is offline
I've had 2 different things cause this. One was a flaky hard drive in my library, not in my recording drives. It impacted playback of any file.
The other was the system time being off. Don't remember if it was the server not synched correctly with real time or the server and client not in synch. At any rate you can check the server time to make sure it is good.
Old 08-01-2014, 08:54 AM
mkanet's Avatar
Thanks for the tip ranger. Although, its not happening anymore, I'll probably end up swapping out my TV Recordings HDD anyway. The disk is quite old.
***RIP SageTV***
Spinning circle when FF or RWD on client only m1abrams SageTV Software 15 01-19-2016 07:09 PM
Spinning circle when trying to play .mpg recordings Patrick25 SageTV Software 1 01-12-2011 07:20 PM
Spinning Circle - somewhat fedup Islander SageMC Custom Interface 38 04-21-2010 07:24 AM
Spinning circle in when accessing recordings autoboy SageTV Software 11 04-08-2009 03:41 AM
FF and spinning circle (strange) bmac.to SageTV Software 7 03-09-2009 10:12 AM
