Old 01-08-2008, 01:13 PM
exponent exponent is offline
Remote control application
I have what is kind of an offbeat (but simple) requirement for recording TV. I have a FTA satellite receiver that has an attached USB drive that can be used to make recordings. unfortunately it has no PVR capabilities so one has to manually start and stop the recording of sat shows. Most of what I will record is HD and I would prefer to use the capabilities of the FTA box as the recordings are quite good. I need a PC based application that can as an example record to channel 101:
1) change the channel at start time. IR sends <1><0><1><OK>
2) IR sends <REC>
3) stop recording at end time. IR sends <STOP>.
It would nice if this could integrate with EPG and have one time and recurring scheduling. I already have the IR codes courtesy of WINLIRC so I am wondering if it is possible to get SageTV to do the above. In a nutshell it would just need to send via IR the number of the channel to bbe change to, the IR REC command and then end with an IR stop. I am thinking of purchasing a USB-UIRT for use and wonder if anyone can comment on whether I can do this with SageTV or not? If not any suggestions on what I could use would be appreciated.
Old 01-08-2008, 09:20 PM
Fastrack Fastrack is offline
Send a message via ICQ to Fastrack
2) IR sends <REC>
You could probably create a custom batch file to do step #1 & 2. But #3 would require custom coding as when a recording ends Sage does not send out any IR code.
Ben
Intel Core2Duo E6600 2.4GHz - Win7 64bit
Antenna: Homemade Gray-Hoverman DBGH, Channel Master 7777 pre-amp, Mid-60s CM Rotor
Tuners: HDHomeRun v1, Hauppauge HVR1600
Video: BenQ W5000 1080p, ASUS ATI 6670
Storage (10TB): Seagate 2TB, Hitachi Coolspin 2TB x 4 Data Drives + 2TB x 2 Parity Drives using FlexRaid 2.0 (RAID6 T2+)
SageTV: 7.1.9 Final ?
JP1 Universal Remote Control (URC-1067) for Hauppauge MVP krasev Hardware Support 0 12-22-2007 12:02 PM
hauppauge remote control doesnt work dknight3 Hardware Support 1 12-17-2007 12:00 AM
Please point remote control... nothing dshields Hardware Support 7 05-10-2006 01:53 PM
Remote control fasan Hardware Support 0 05-10-2006 08:48 AM
USBUIRT - Remote Control Problems Questions mike1961 Hardware Support 8 04-05-2006 10:39 PM
