Old 02-21-2011, 02:34 AM
mkanet's Avatar
mkanet mkanet is offline
Diamond Sub-theme: Diamond MKANET Mod
Hopefully its okay with all the developers that I share my personal sub-theme for Diamond. It's available for download under the "Theme" section under plugins. I was having problems viewing certain items in Diamond themes such as folders, background fanart, text on main menus; so, instead of bugging the very busy developers with requests and suggestions, I decided to make a sub-theme that suited my taste better. I expect to have to update the sub-theme after the next Diamond release.
Standard Diamond Main Menu: (Before)
MKANET Mod Main Menu: (After)
Standard Diamond TV Menu #1: (Before)
MKANET Mod TV Menu #2: (After)
Standard Diamond TV Menu #2: (Before)
-Michael
* split to its own topic *
***RIP SageTV***
Old 02-21-2011, 04:50 AM
jorton jorton is offline
-Michael
Hi Michael,
If you had really wanted to know if it was ok to post then you should have asked first
If you had asked, I would have suggested that if you are going to take this on (creating and maintaining a plugin) that you start your own thread where you can update and support your sub theme and mods. It may also become confusing for users if you are posting info or supporting your own theme in the main Diamond thread.
I believe the common practice is to have a separate thread for each plugin.
Regards and good luck with your plugin(s).
Jeremy
Old 02-21-2011, 05:18 AM
mkanet's Avatar
Hi Jeremy, I dont have any intentions in providing support for this sub-theme for others. I didn't expect to be a need for that. It's just my personal sub-theme that I thought I'd share "as-is". Hence why I didnt start a dedicated thread with respective collaboration. I just thought this was a quick and easy way to let other diamond users know there's an optional sub-theme. Sorry if I went about it wrong. Please dont kill me for that
-Michael
Originally Posted by jorton View Post
Hi Michael,
Jeremy
***RIP SageTV***
Plugin: Diamond Theme jorton Diamond 960 03-04-2011 12:17 PM
Diamond Theme Genre Images PLUCKYHD Sage My Movies 23 11-07-2010 07:11 PM
Big Thanks To JOrton for upcoming Diamond Theme!! PLUCKYHD Sage My Movies 10 10-23-2010 02:34 PM
Diamond Pattern on Digital TV Jimb50 SageTV Software 5 12-25-2008 07:40 AM
Diamond Multimedia 30% off sale GKenny The SageTV Community 6 09-21-2005 05:17 PM
